Automating optimal placement of horizontal wells
1029
04-03-2013 07:49 AM
KevinMyles
I am a GIS student completing a project for determining the optimal placement of horizontal wells (drilling) based on a set of engineering rules. The project is for an external client and not standard course curriculum.
I will need to automate the drawing of new lines (horizontal drills) from polygons (well pads) based on a set of provided rules (buffers between all drill lines), as well as interact with other vector features such as stopping at 100m of the end of a quarter section boundary or not stopping at or under a road allowance.
I have taken an ESRI tutorial on Linear Referencing and have tried using COGO editing tools. These will be helpful but at this point I am having difficulty with just the basics of drawing the lines and moving them based on direction/angle/buffer with the context of the rules provided.
The rules are:
-Well paths must 200m apart from each other
-Start and end 100m from land or holding boundary
-Max 8 wells/pad
-Pads 240M by 120M
-Spacing 4 wells/section(640 acres) or I well/Quarter section(160Acres)
-100m from quarter sec boundary
Any help with line editing or similar existing models etc?
KevinMyles
Can anyone chime in with any other advice for vector editing. Also anyone with Oil & Gas experience, have you seen anything similar? Does this seem like too lofty a goal for student fairly new to geoprocessing? Thanks!
KevinMyles
