URL " http:// <server>/ArcGIS/rest/service/GPTask/MapServer/jobs/<jobid>" not found
1196
04-10-2013 09:23 PM
ShabeeraliAzhuvalappil
Hi
I am Using ArcGIS Server 10.03 SP3. I created a geoprocessing service in the server which returns a result map service. I successfully created the gp service and map service with same name. I need to display the result in my application using ArcGIS Javascript API v3.3.
The logic works like the sample application  http://developers.arcgis.com/en/javascript/samples/gp_resultmapservice/
I tested the gp service in the REST Web interface and successfully executed.The result map is obtaining after completion of the task.
But when I use it in the JS API (ver. 3.3) front end , the fire bug tool shows success execution of the gp task , but when it executes
map.addLayer(gpLayer);
the response shows
    dojo.io.script.jsonp_dojoIoScript9._jsonpCallback({"currentVersion":10.03,"error":{"code":400,"message":"Unable to complete  operation.","details":["Invalid URL"]}});
When I tried the url  http:// <mygisServer>/ArcGIS/rest/service/GPTask/MapServer/jobs/<jobid>
The page not found error shows.
When I changed the code with
    gp.getResultImageLayer(jobinfo.jobId, "output", imageParameters, function (gpLayer) {
I got  the result .
Can anybody help to find the exact reason? I need to include the service via ArcGISDynamicMapServiceLayer
Here is the My sample code that Did not work
    function applyGPTask() {
    var gpServiceUrl = "http://localhost/ArcGIS/rest/services/GPTasks/GPServer/GPTask";
    gp = new esri.tasks.Geoprocessor(gpServiceUrl);
    var params = {
        param1: "SUBDIVID=202",
        param2:"value2",
        param3: "value3"
      gp.setOutputSpatialReference({ wkid: 4326 });
      gp.submitJob(params, gpJobComplete, gpJobStatus, gpJobFailed);
    function gpJobComplete(jobinfo) {
    var mapurl = "http://localhost/ArcGIS/rest/services/GPTasks/MapServer/jobs/" + jobinfo.jobId;
    var gpLayer = new esri.layers.ArcGISDynamicMapServiceLayer(mapurl, {
        "id": "gpoutput",
        "opacity": 0.7
I find out the issue. The above program is only work with ArcGIS 10.1 Server ,I think if I upgrade my 10.03 version server with 10.1 this feature will work
