arcpy and pmf
8675
23
02-02-2010 10:29 AM
TedCronin
Will the generation of pmf files be supported with arcpy?  I don't remember seeing anything in the help.
MarkCederholm
As far as I can tell, there is no Publisher support in arcpy, nor can you use it to check out the license.  This is a textbook situation where you want to use ArcObjects instead (see my presentation at the upcoming DevSummit).  I've attached an example script.
TedCronin
yes, comtypes is pretty cool, thanks for the script, will give it a spin.
BartHound
Mark -
Have you looked at IronPython with clrtypes, to do all the arcobjects, just inquiring?
MarkCederholm
Not yet; I plan to eventually, though I hear IronPython's performance leaves something to be desired.  Right now, I'm focusing on the Python shipped with ArcGIS.
MarkCederholm
FYI, I've now added IronPython to my list of COM interop performance benchmarks.  Here are the relative scores for calculating the average area of 500+K polygon features at 9.3.1:
VBA:   1.00
C++/Native:  1.00
Python/comtypes:  3.54
VB .NET:   3.54
Python/arcgisscripting: 3.62
IronPython:  4.78
TedCronin
Which version of Ironpython does this refer to?  What's interesting to me is the tie:
VB .NET:  3.54
kinda makes you not want to use vb.
MarkCederholm
IronPython is 2.6, CPython is 2.5.1, comtypes is 0.6.1
TedCronin
Any testing with 2.6.2 with arcpy? Or is comtypes not ready for 2.6?
JasonScheirer
Esri Alum
Have you tried benchmarking your Python scripts against Python with psyco enabled? I wonder how much it would help, if the bottlenecks on the Python side can be significantly optimized away.
