ArcMap 10.3 Orphaned Processes
5960
6
02-06-2015 09:46 AM
TomSellsted
Anybody having any issues with ArcMap leaving an orphaned process running?  Every time I run ArcMap 10.3 and exit the application it leaves behind an orphaned process.  It doesn't appear to be using any CPU, but depending on the MXD, it retains the memory it was using.  This does not happen with ArcCatalog.
I am using ArcMap 10.3 on a Windows 7 Pro with service pack 1 and also on Windows Server 2008 R2 Enterprise.
TomSellsted
The orphaned process also appears to lock any datasets that are being used too.  I tried reopening an MXD and adding a field to a feature class and got an error message stating that the resource was in use by another process.
JayantaPoddar
Hi Tom,
Open a fresh ArcMap (with no ArcMap.exe in background). Work on it. Try closing from File > Exit.
Does the ArcMap.exe still exist in the background processes?
Jay
Think Location
TomSellsted
Thanks Jay!  I did give that a try.  It did not leave an orphaned process, but ArcMap did crash when exiting.  While in my project, I did some editing, switching between the layout view and data view, open some layer tables and exported a PDF.  I tried again doing even less and it still crashes, but does not leave an orphaned process.
I have seldom exited using File>Exit to exit ArcMap.  I almost always use the X.
Best Regards,
Tom
JayantaPoddar
Hi Tom,
Could you try the following steps and let me know if the ArcMap still crashes on File > Exit.
Go to Start > Run, type in the command below and click ok:
%AppData%\ESRI\Desktop10.3\ArcToolbox
How big is the ArcToolbox.dat file? If it is over several MB in size, rename it to ArcToolboxOld.dat and try again.
Jay
Think Location
TomSellsted
Jay,
It is only 231KB.  Very small.
Best Regards,
Tom
TomSellsted
Greetings Posters,
I have just installed 10.3.1 and the problem still exists.  If I exit by clicking the X in the upper right hand corner, ArcMap leaves an orphaned process.  If I File>Exit ArcMap crashes.
Regards,
Tom
