ArcGIS Locate Features Along Routes no results
1314
03-05-2018 12:07 PM
cphphc
I have used this tool successfully before in ArcGIS 10.1. This time I want to locate some points along a polyline (with m property), after setting all the input parameters, the tool proceeds just fine, no warnings or failures, but nothing came out in the result table except the column names. And I triple checked that there are multiple points locates within the search radius which is 40 meters of the input route.
And then I drew my own polyline and points, and applied them in this tool, the same problem occurs.
I tried on an older version-10.1 with the same data, the same problem showed up.
What's going wrong?
Both the original data and the data I created are attached below.
My ArcGIS version is 10.2.2
cphphc
Create Route! Remember, the first thing to do is to create a route, polyline m is not enough!!!
cphphc
