Arc 9.3 exporting PDF problem
1232
04-30-2013 03:33 PM
AlexSchild2
Trying to export mxd as PDF and keep running into this issue (attachment). In short, the basemap and some of the symbology didn't export. Thanks.
NAOMIPAUL
Are you using any transparency?
Exported PDF of ArcMap document does not include the features if layer is using feature level transparency. I have also seen it not export everything below the feature layer with transparency used.
RobertBorchert
Honored Contributor
You should use the setting to embed the fonts.
Play around with the transparency levels.
