Arc 9.3.1 failure to intersect
5648
17
07-26-2017 06:43 PM
WalterWitt
Using ArcGIS 9.3.1, I successfully executed an Intersect between two polygon shape files (I tried intersecting 3 shape files first but the license won't allow that apparently. So, I then tried to intersect the successful intersection with the third file, using a second Intersect. This repeatedly fails. I tried the same Intersect at another institution using Arc10.0 but got the same failure. Is Arc detecting that one of the files is already the product of an intersect and therefore denying me the chance to intersect a third file? The error message I get is:
Executing: Intersect "'Intersection_diek buffer_F2 buffer' #;'br200k_lithological_unit_prospective units' #" "L:\Nero_Alternate\Kuusamo_GIS\Finnish GTK stuff\FS_Geology\200k_Finland_tm35Fin\Arc translations\Intersection_dike_F2_prospunits.shp" ALL # INPUT
Start Time: Thu Jul 27 09:36:41 2017
Reading Features...
Cracking Features...
ERROR 999999: Error executing function.
Invalid Topology [M coord limit exceeded.]
Failed to execute (Intersect).
End Time: Thu Jul 27 09:36:43 2017 (Elapsed Time: 2.00 seconds)
JoshuaBixby
MVP Esteemed Contributor
Have you read Error: 999999: Coordinate limit exceeded ?  Does it help?
Also, ArcGIS 9.3.1 was retired on 12/2013 and ArcGIS 10.0 was retired on 01/2016.  It is getting more and more difficult for GeoNet users to comment on those older versions since so few people are running them and there have been hundreds, and maybe thousands, or bug fixes since 9.3.1.
Good luck.
WalterWitt
It wasn't retired by me
JohnPlunkett
Have you tried doing this on your local C:\ rather than a network drive?
JohnPlunkett
Also see this link here
WalterWitt
Ive tried it now but without success. Thanks for the thought
WalterWitt
I have read the Error: 999999 notes but they don't help because I don't understand
JayantaPoddar
What is the coordinate System of the inputs? Ensure they have a Projected Coordinate System (Units: Meters / Feet) and it is same for all inputs.
Think Location
WalterWitt
Both have exactly the same projection and co-ordinate system
JayantaPoddar
What is the Coordinate System (PCS)? Could you attach a snapshot?
Think Location
