Analyze script tool in Pro doesn't work
898
02-10-2023 08:43 AM
DHighness
I'm having a horrible time trying to publish script tools in ArcGIS Pro to ArcGIS Server. Currently I have a script tool that does pretty much nothing. It runs through cleanly in Pro but when I try to share it as a Web Tool I can never get past the Analyze which appears to be required. It would be great if that could be circumvented in some way because it seems to be the biggest computer Karen ever invented. Please let me worry if my script is going to function or not!
Anyway, my script tool hangs at Analyze. The script does nothing! I've been publishing script tools to Server from Desktop for a decade!
To make matters worse, when I get these script tools to Analyze, I publish the simple one and then go in to the services folder and replace the script tool with the real python script. The real script will never ever analyze!
import arcpy, os, time, traceback, sys
def main():
    try:
        #get the oids parameter
        state_abbrv = arcpy.GetParameterAsText(0)
        cnty_name = arcpy.GetParameterAsText(1)
        uscong_dist = arcpy.GetParameterAsText(2)
        program = arcpy.GetParameterAsText(3)
        scr_ws = arcpy.env.scratchWorkspace
        arcpy.env.parallelProcessingFactor = "25%"
        # map documents
        inFldr = r"\\drive\share\folder"
        # PDF files
        nowDt = time.localtime(time.time())
        sdt = time.strftime("_%Y%m%d_%H%M%S", nowDt)
        outFilePdf = os.path.join(scr_ws,"Summary_Rpt" + sdt + ".pdf")
        pdfDoc = arcpy.mp.PDFDocumentCreate(outFilePdf)
        pg = os.path.join(inFldr,"publish.pdf")
        pdfDoc.appendPages(pg)
        pdfDoc.saveAndClose()
        del pdfDoc
        arcpy.AddMessage("PDF completed")
        #Set the output parameter
        arcpy.SetParameter(4, outFilePdf)
        arcpy.SetParameter(5, outFilePdf)
        return
    except arcpy.ExecuteError:
        # Get the tool error messages
        msgs = arcpy.GetMessages(2)
        # Return tool error messages for use with a script tool
        arcpy.AddError(msgs)
        return
    except:
        # Get the traceback object
        tb = sys.exc_info()[2]
        tbinfo = traceback.format_tb(tb)[0]
        # Concatenate information together concerning the error into a message string
        pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
        msgs = "arcpy ERRORS:\n" + arcpy.GetMessages(2) + "\n"
        # Return python error messages for use in script tool or Python Window
        arcpy.AddError(pymsg)
        return
#Main part of the script
if __name__ == '__main__':
    main()
    arcpy.AddMessage("Export completed")
DHighness
This thing finally did Analyze and I got it published but this is ridiculous! I need a way to circumvent the Analyze. I'm still going to have to go on Server to the "arcgisinput" folder and replace the published script with the real one.
