Hello, I created a function to round the values of the results on my script which queries the atlases by selecting a layout, but when executing it I have the following error: An invalid SQL statement was used.
here is the function:
for field in liste:
with arcpy.da.UpdateCursor(r'in_memory/resultats_table', [field]) as cursor:
for row in cursor:
if row[0] == None:
pass
else:
row[0] = round(row[0], 2)
cursor.updateRow(row)
Solved! Go to Solution.
thanck you for your help johannes, but i have the same error.
That is because you left in your old code (lines 55-64) and didn't use the suggested code beginning at line 67.
