All geoprocessing tools hang after failed function
876
11-13-2019 06:31 PM
KimFalinski
Hello,
I was trying to run a Spatial Analyst function and now I cannot run any geoprocessing tools.  The function was considered "Did not Run" - all I got was an hour glass in Results.  Now I cannot run anything.
Things I've tried:
Restarting computer
Restarting ArcGIS
Turning off internet
Using a different mxd.
Running as administrator.
I'm on Windows 7, version 10.2.2.  I did update my computer 2 weeks ago (only rarely do it manually).
Please help!  I was trying hard to finish a project and now cannot do anything.
DanPatterson_Retired
Windows Control Panel, Add/Remove Programs, select Repair (under remove) from the options to see if it has an easy fix
KimFalinski
Thanks for the reply, Dan.  I went through with the Repair, but alas, nope - can't even execute a simple Buffer.  so frustrating.  Is the only hope a re-install?
