AddLayer only temporarily adds the layer to map
4434
11
07-15-2010 09:37 AM
ChristianHalsted
When I run the following code:
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
addLayer = arcpy.mapping.Layer(r'G:\data_layers\political\Towns_Maine_polys.lyr')
arcpy.mapping.AddLayer(df, addLayer, "AUTO_ARRANGE")
from the Python Window in ArcMap it works fine.  But when I put it in a script tool and run it from ArcToolbox I see the layer get added to the data frame but then it immediately disappears.
I've tried using InsertLayer but get the same result.
Any idea what is happening?
ionarawilson1
I think it might not have to do with the lenght of the array collection. When I add another if clause ( else if (ac.length == 3)), that filter that I had before (when I typed "ref" and filtered two values to the array collection) stopped working. So it  might have to do with the creation of another variable actually. I noticed that if I don't create qText4, then the filter for the two values work. So maybe the function is not executing anymore since when it filters to two values, it cannot get the third value and it therefore cannot create that 3rd variable that goes in the if clause. Do you have any idea why this is happening? Thanks!
 private function doSearch():void
    myAttributeTable.refresh();
    myAttributeTable.visible = false
    ac = new ArrayCollection();
    ac.addItem({name:"Alpine",code:"AL"});
    ac.addItem({name:"Austin",code:"AU"});
    ac.addItem({name:"Referral - Consulting Forester",code:"RC"});
    ac.addItem({name:"Referral Vendor", code:"RV"});
    ac.addItem({name:"Incidental Rural Forestry",code:"AIR"});
    ac.addItem({name:"Prevention and Reduction of Pest Losses",code:"AP"});
    ac.addItem({name:"Forest Health Monitoring - Survey",code:"FHS"});
    myAttributeTable.featureLayer = myFeatureLayer
    myAttributeTable.featureLayer = yourTable
    myAttributeTable.visible = true
    ac.filterFunction = filter;
    ac.refresh()
    var itemname:String = ac.getItemAt(0).name
    Alert.show(itemname)
    var itemname1:String = ac.getItemAt(1).name
    Alert.show(itemname1)
    var qText2:String  = ac.getItemAt(0).code
    var qText3:String = ac.getItemAt(1).code
    var qText4:String = ac.getItemAt(2).code
    Alert.show(qText2)
    Alert.show(qText3)
    yourTable.refresh()
    if (ac.length == 1)
     Alert.show("TEST AC LENGTH 1")
     var defexpr:String =  searchattribute +  "like" +  "'"  +  qText2  + "'";
     yourTable.definitionExpression = defexpr
    else if (ac.length == 2)
     Alert.show("TEST AC LENGTH 2")
     var defexpr2:String =  searchattribute +  eqsymbol +  "'"  +  qText2  + "'" + " OR " + searchattribute +  eqsymbol +  "'"  +  qText3  + "'";
     yourTable.definitionExpression = defexpr2
         Alert.show("TEST AC LENGTH 3")
         var defexpr3:String =  searchattribute +  eqsymbol +  "'"  +  qText2  + "'" + " OR " + searchattribute +  eqsymbol +  "'"  +  qText3  + "'" + " OR " + searchattribute +  eqsymbol +  "'"  +  qText4  + "'";
         yourTable.definitionExpression = defexpr3
         Alert.show(defexpr3)
    else if (ac.length > 2)
     Alert.show("TEST AC LENGTH ELSE")
     Alert.show("Please review your search and try again")
MathiasKP
These lines will add a layer with SP10.1:
but if you try other things like using the Layer.replaceDataSource method the layer will disappear again. I have not tried all methods/properties combinations but they might fail as well as some of you have experienced.
/Mathias
