Adding Interactive Components to a Model
1682
04-23-2014 10:45 PM
BruceBurwell
Greetings
I am trying to develop a model that will create contours from a smaller location defined by the user. I would like the process be set up so that when a user runs the model, they are prompted to draw an area of interst on the map which will be used as a clip tool to extract the area and then contour. How do I set up the interactive part? This will eventually be shared as a geoprocessing service.
Regards
Bruce Burwell
Sudi Aramco
HåvardMoe
Check the help file for "Creating model parameters".
If you set a model variable as a parameter, it will prompt you in a dialogue for it when you run the model as a tool.
BruceBurwell
Thanks, that fixed my problem.
HåvardMoe
Glad to be of help.
Now, if you tick the little on the right side, the thread will be marked as answered out as well. 🙂
