Adding data
10571
25
02-13-2017 10:20 AM
janehansen
I have a spreadsheet with the coordinates in DD. The Longitude numbers did not have a - in front. For example 114.235 not -114.235. So I added another column named Long and added the -.  I then tried to import the data into arc map using add data xy but the Long column does not show up as one of my options in the add data xy box.  I am assuming it has something to do with the original Longitude columns formating????
Jane
janehansen
Actually I did follow your steps. I imported the original spreadsheet as a
table to the gdb...I used the field calculator to add a - in front of the
long numbers. Then, I used this table to import into the x y fields of the
add data.
AbdullahAnter
Honored Contributor
if so , that problem I think relate with your spatial reference.
what is spatial reference you use?
janehansen
I used wgs 84.
Sent from my iPad
DanPatterson_Retired
While you are doing all this, are you adding the data to a new empty data frame without any other layers in it?  If the data adds to a clean untouched dataframe, then you have the starting point to begin dissecting the issue.
janehansen
Yes that is exactly what I did...nice to know I was on the right track.
Thanks for your input.
Jane
janehansen
It did work thanks for sticking with me...
Jane
