Adding coordinates into ArcMap - Help needed
6832
12
08-13-2014 08:23 AM
AmySteel
Im working with a DEM downloaded from Digimap of the Orkney islands to asses the visibility impacts of wind turbines using a view shed analysis. I've complied a document of the wind turbines in Excel to use for the analysis, with their locations in British national grid - Eastings and Northings. However, the problem that I'm having is that I can get this to import into ArcMap and work. If i import with the BNG from a tab delimited file or normal workbook then Arc doesn't reconise any data is present and lists everything as a column - if i have 30 rows of data then there will be 30 columns all labelled fields 1-30.
If i convert to decimal degrees as I read online this might be easier, then the longitude value is a Negative, but this won't display either the fields just display as 'Null'. I have tried adding the compass bearings on to the end of each number to see if this helps but no luck and I have then removed this and made sure the cells are formatted to 'Number' but again it still displays as 'Null'. I have spent hours looking online and cannot find a reasonable solution..
Any help would be much appreciated
Tags (1)
DanPatterson_Retired
copy the fieldnames and the first couple of rows of the data so we can look at it.
If you are still working in a spreadsheet, you need to explicitly format the column to an appropriate decimal type, if you just remove the N from the cell entry, it is still text even though it looks like a number.  Also, by default text is left justified and numbers are right justified.
ps there is no attachment
JoeFlannery
Honored Contributor
I'm using ArcMap 10.2.1 and brought the xls file directly into ArcMap with no problems.
ScottDean
You may also want to look at this toolbox which has conversion tools but I am not sure what ArcGIS version you are running.  This is for 10+.
http://www.arcgis.com/home/item.html?id=f3d91b8f852042e289e09a7ec8342431
