accumulate segment lengths of a polyline
1003
04-09-2010 12:55 PM
QuayeTrimble
I need a way to accumulate the segment lengths of a polyline.  Each individual segment contains its associated length and contains a unique id which is specific to each feature.  I'm inexperienced with python but learning as I go.  Can anyone provide some ideas or a reference to an existing script that may help to get me started ?
This might help with any questions about what I'm trying to achieve.
ID|LENGTH|CUM_LENGTH
1 |10|10
1 |14|24
1 | 9|33
2 | 6| 6
2 |13|19
2 | 8|27
RDHarles
This should work assuming your ID field is sorted like you have in the example.
# Import modules and create the geoprocessor object
import arcgisscripting, sys, os
gp = arcgisscripting.create()
gp.workspace = os.getcwd()
# File to process
shp = "Adminbndy1.shp"
# Set total to zero and start a blank list
total=0
keepTrack=[]
# Create update cursor for feature class.
rows = gp.UpdateCursor(shp)
row = rows.Next()
while row:
    # Get the values from the fields
    id = row.GetValue("ID")
    len = row.GetValue("LENGTH")
    # If id is unchanged
    if id in keepTrack:
        # Add length to the total
        total = total + len
    # If id changes
    if not id in keepTrack:
        # Total starts over as length value
        total = len
        # Clear the id list
        keepTrack=[]
    # Keep track of the id
    keepTrack.append(id)
    print "id: "+str(id), "length: "+str(len), "total: "+str(total)
    # Write the total to field "CUM_LENGTH"
    row.CUM_LENGTH = total
    # Execute the new value to the table
    rows.UpdateRow(row)
    # Go to the next
    row = rows.Next()
del rows
RDHarles
Here's the code with the proper indenting (I finally figured out how to post code properly on this new site).
# File to process
shp = "File1.shp"
total=0
keepTrack=[]
row = rows.Next()
while row:
    if id in keepTrack:
        total = total + len
    # If id changes
        total = len
        # Clear the id list
        keepTrack=[]
    rows.UpdateRow(row)
    # Go to the next
    row = rows.Next()
del rows
VivekGaikwad
Dear Sir,
Please help me on how to use this code in ArcMAP Application.
# File to process
shp = "File1.shp"
total=0
keepTrack=[]
row = rows.Next()
while row:
    if id in keepTrack:
        total = total + len
    # If id changes
        total = len
        # Clear the id list
        keepTrack=[]
    rows.UpdateRow(row)
    # Go to the next
    row = rows.Next()
del rows
RDHarles
1.) Make sure your shapefile has the 3 fields that the script lists: ID, LENGTH, CUM_LENGTH
(if not, edit the script to match you fields names)
2.) Save the updated code (posted below) as a python script on your system.
3.) Follow these directions:
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Adding_a_script_tool
4.) When you get to step 11, put in the following under the two headings:
DisplayName    DataType
Workspace    Workspace
Shapefile    Shapefile
5.) ...then execute the script
#gp.workspace = os.getcwd()
gp.workspace = sys.argv[1]
# File to process
shp = sys.argv[2]
total=0
keepTrack=[]
row = rows.Next()
while row:
    if id in keepTrack:
        total = total + len
    # If id changes
        total = len
        # Clear the id list
        keepTrack=[]
    rows.UpdateRow(row)
    # Go to the next
    row = rows.Next()
del rows
