StreetMap Premium for ArcGIS Runtime<\/A> offers high-quality, worldwide street data optimized for use in cartographic map display, geocoding, and routing. This data can be integrated into apps developed with the ArcGIS Runtime SDKs<\/A> from version 100.0 onwards. They are stored locally on the user's device – enabling use on the go and without an internet connection. The data is updated regularly to ensure it is always up to date, allowing the development focus to be solely on creating and maintaining the actual apps.<\/P><\/P><\/P><\/P>The following advantages are offered by StreetMap Premium for ArcGIS Runtime:<\/P><\/P> <\/SPAN>Detailed street base map<\/STRONG><\/SPAN> The data provided with StreetMap Premium for ArcGIS Runtime has already been processed and is available as a ready-to-use street base map. This high-quality base map provides the necessary spatial context in the apps.<\/SPAN><\/LI> <\/SPAN>Search and geocode locations<\/STRONG><\/SPAN> StreetMap Premium for ArcGIS Runtime includes a Locator Task for geocoding that can be easily integrated into apps. With this locator, users can search for specific addresses, intersections, or Points of Interest and display them on a map.<\/SPAN><\/LI> <\/SPAN>Solving routing problems<\/STRONG><\/SPAN> StreetMap Premium for ArcGIS Runtime also offers a network dataset for transportation networks for comprehensive routing analysis functions in ArcGIS Runtime apps. This data enables determining optimal routes between different locations in the street network.<\/SPAN><\/LI> <\/SPAN>Offline use of street data<\/STRONG><\/SPAN> The data available in StreetMap Premium for ArcGIS Runtime is also accessible when there is no internet connection. This allows users to conveniently access base maps, geocoding functions, and routing functionality even in fieldwork or areas with poor or no internet connectivity. Another advantage is the reduced amount of data that needs to be transmitted – saving costs.<\/SPAN><\/LI> <\/SPAN>Apps for use worldwide<\/STRONG><\/SPAN> The data and maps from StreetMap Premium for ArcGIS Runtime are available worldwide. Mobile map packages for various areas, e.g., regions or countries, can be integrated into apps.<\/SPAN><\/LI><\/UL><\/P><\/P>
<\/P>
For deploying finished apps, StreetMap Premium for ArcGIS Runtime must be licensed as an extension to ArcGIS Runtime. The license key(s) (licensed per region) are also implemented in the code like an extension. More information on the procedure
<SPAN class="keyword token">var<\/><SPan class=\"operator token\">=</SPan> <Span class=\"keyword token\">await<\/> MobileMapPackage.OpenAsync(Path to mmpk);
Signed in members can post, follow updates, and more. New here? Register a free account.
