sql server express database
1239
10-03-2018 04:43 AM
ikbelkachbouri
I created an sql server express database but I could not attach it with arccatalogue.
an error message appears to me:
JoshuaBixby
MVP Esteemed Contributor
Sharing with Geodatabase‌.
This isn't an ArcGIS error/issue but a SQL Server error/issue.  If you search the web, you will find plenty of examples of this error and suggestions on fixing it.  For example, SQL Server Operating system error 5: "5(Access is denied.)" - Stack Overflow and How to Get Rid of SQL Server Database Access Denied Error
Asrujit_SenGupta
The user doesn't have necessary permissions on the windows folder to perform the attach.
Just copy the files to some other folder\drive and try the process.
