Geodatabase conection issue
1346
09-28-2018 02:26 PM
SandraWang1
Anyone can share the tips or solution for the slow connection from ArcGIS 10.3.1 and ArcGIS 10.5.1 after Geodatabase has been upgraded from SDE 10.1 to 10.2.2 then 10.3.1 ? The Oracle version has been upgraded from 11.2.0.4 to 12.1.0.2.
I had done several tuning on Oracle side including increasing SGA size , PGA size and also some Oracle parameters but still no help. I have also even run the  following work around to add "open_cursor" parameter in server_config table, not really help either.
Greatly appreciated your help ..
I have attached the trace file FYI..
Sandra Wang
George_Thompson
Esri Notable Contributor
It may be best to contact Esri Technical support and work with an analyst on this. You may have to do some client tracking and analysis.
--- George T.
MichaelVolz
Esteemed Contributor
Do you plan on upgrading SDE to 10.5.1 to match your client?
SandraWang1
Thank you. Yes I am having a ticket open but no solution yet.. That's why I tried to see if any one had any experience or tips..
