Select maximum values in Select By Attributes (greatest n per group)
16247
24
01-11-2024 07:04 PM
Bud
Legendary Contributor
ArcGIS Pro 3.2.1; mobile geodatabase
I'm trying to learn about different ways to select the greatest n per group in ArcGIS Pro. I came across this old ArcMap article that talks about a possible technique:
Select minimum and maximum values in the Select By Attributes window in ArcMap
Use GROUP BY subquery clauses to return values from aggregate functions on sets of values.
Example #3:
Select the records from the table with the most recent date for sets of values, where <group_ID> is the field that contains the values that define the groups:
<date> = (SELECT MAX(date) FROM <table_name> GROUP BY <group_ID>)
I'll use the SQL expression above to try to select the latest row per species group. The result looks like this:
t_date = (
    select
        max(t_date)
    from
        species_records
    group by
        t_species)
That's not the result I was looking for.
This would be the result I'm looking for:
t_date in (
    select
        max(t_date)
    from
        species_records s2
    where
        s2.t_species = species_records.t_species)
What am I missing in that article?
Notes:
  • I'm aware that there will be duplicate rows selected per group if there are multiple rows per species that have the same date. Breaking the tie (arbitrarily) would be ideal. But I don't know if that's possible with this particular approach.
  • I've attached sample Excel data that can be loaded into a geodatabase.
Thanks.
Bud
Esri Case 03529800 - FGDB database view: Can't use CAST function in WHERE clause
BUG-000164429: When creating a database view, using a cast function in the where clause results in an error
jlgprime
The generalized greatest-n-per-group solution worked for me after copying my table to a mobile geodatabase, thank you @JoshuaBixby !
Bud
Regarding not being able to create a database view with CAST in the WHERE clause, that is interesting because CAST works in the Select By Attributes tool, which of course is the WHERE clause:
CAST(t_date AS CHAR(20)) IS NOT NULL
I looked at the Diagnostic Monitor in ArcGIS Pro to see what SQL query Pro sends to the database when using CAST in Select By Attributes. I had wondered if it was doing something special, such as wrapping something in a subquery or outer query, which can be an effective workaround in some cases.
Examples:
But no, the query looks normal.
SELECT OBJECTID FROM species_records WHERE CAST(t_date AS CHAR(20)) IS NOT NULL
I tried using that exact SQL to create a FGDB database view. But it failed, just like previous attempts to use CAST in the WHERE clause of a FGDB database view.
I also tried adding an extra column to the SELECT clause, just in case it didn't like only selecting the ObjectID. But that didn't work either.
SELECT OBJECTID, t_species FROM species_records WHERE CAST(t_date AS CHAR(20)) IS NOT NULL
ERROR 160195: An invalid SQL statement was used.
Of course, I don't have this problem in mobile or enterprise GDB database views.
Bud
Surprisingly, wrapping the WHERE clause CAST in a subquery seems to work. I'm able to create the view.
select
from
    species_records
where
    objectid in (
        select
            objectid
        from
            species_records
        where
            cast(t_date as char(20)) is not null
Bud
