I had to reinstall Windows 7 after Windows 10 crashed and then reinstall ArcGis Desktop. The computer could never get past the Advanced Diagnostics Screen so I had to remove the driive and use another computer to copy my files. After re-installation and copying the files back I get an error message when trying to access my file geodtabase.
Failed to connect to database
This release of the GeoDatabase is either invalid or out of date [Invalid Geodatabase release].
How can this be when it was created using the same version of arcmap?
Help. I have three years worth of data trapped in this geodatabase.
Thank you. I actually had to run the utility on another machine with a newer version of the program. My program couldn't run the utility without being able to connect to the database.
I don't know how to move the thread.
Richard L. Morrison
Doe Hall Creek Timber Company, Llc
1519 Village Square
Mt. Pleasant, SC 29464
843-209-7725
I'm not a moderator for this space, but will tag Christopher Catania
but you can read thru Moving Content to do it yourself.
And in general, you can mark your own answer as correct if that is the best (mark other responses that are helpful) or if no correct answer you can mark it as "assumed answered" instead. Either will close a thread and make it easier for others with the same issue and looking at the post. Thanks.
Rebecca - I've marked the response to the question correct and moved to the Geodatabase group. Thanks to all for helping out on this thread!
