[This question was branched from a previous question - VJA]
Hello Michael , I realized you could connect the postgresql with arcgis , I would like some help if possible.I'm trying to connect postgresql 9.1 / 2.0 postgis with Arcgis 10.3 and I'm not succeeding . When I'll try the connection in ArcCatalog the following message appears . "Failed to connect to the specified server . Continue? You can not connect to the database because the client software failed initialization. Make sure that the database client software is installed and configured correctly. "Follow the procedures in this link: http://desktop.arcgis.com/en/desktop/latest/manage-data/gdbs-in-postgresql/setup-geodatabase-postgresql-windows.htm
Diego Varela The issue that you are observing is different from what this original Post was created for. You should have posted your issue as a new Question.
Looking at your issue, it seems to be a client files issue. However 10.3 Desktop should automatically have those.
I am attaching a copy of the required Client files from a Desktop 10.3 installation at my end. Copy these to the Desktop>Bin folder at your end and then check if that helps.
NOTE: Keep a copy of the Bin folder from your end as backup, if you are trying the above.
Thanks Asrujit, I apologize for not having created another post. I managed to make the connection to the ArcGIS 10.3 thanks to the DLL files that you sent me. However , I can not edit the postgresql files, the message " early edition has encountered one or more layers with errors or warnings and can not continue " appears in the " START EDITING " and appears in the description field the following messages " no editable layer " and " The desktop containing this data can not be edited ."
