Oracle Geodatabase upgrade issue - Version 11.3
2470
01-08-2025 08:58 AM
Felipe
Hello Community,
I am trying to upgrade an Enterprise Geodatabase from the version 11.1 to the version 11.3, running on Oracle Database 19c Enterprise Edition Release 19.0.0.0.0 - Production
Version 19.24.0.0.0.
But I am receiving the following error:
Could not upgrade multiple schema or database instance. [The master geodatabase contains user schema geodatabases which should be upgraded separately after the master geodatabase is upgraded.
Id Version Instance
It is weird because I am connected with the SDE user and I am sure that it is the master geodatabase schema.
Is there an efficient way to query this error in the database admin tables?
I already upgraded other geodatabases using the same ArcGIS Pro installation, and it worked normally. It discarded the possibility to be a problem with the ArcGIS Pro, Oracle client or Oracle version.
Did somebody had similar issue recently?
Any help would be much appreciated.
Thank you.
KR
Felipe
MarceloMarques
Hello @Felipe
Esri User-Schema Geodatabases in Oracle are deprecated.
Read more in the blog articles below.
ArcSDE User-Schema Geodatabases in Oracle are deprecated
Oracle 23ai (23c) Support for ArcGIS
Enterprise Geodatabase in Oracle CDB & PDB - Best Practices and Recommendations
Regards,
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
VinceAngelo
Esri Esteemed Contributor
User schema geodatabases have been deprecated for more than four years. Are you sure this is even possible?
- V
Felipe
Hi @VinceAngelo , thank you for your answer!
Indeed, it is very strange, and the message shows an empty list when I get the error:
More or less 6 months ago, this database has been successfully upgraded from 10.9.1 to 11.1, with no errors:
Do you think the error is coming from some corrupted table?
Thank you!
VinceAngelo
I think the deprecation is being enforced by 3.3/10.3.
- V
MarceloMarques
Hello @Felipe
Regards,
Felipe
Hello @MarceloMarques
Thank you for all the information. I have requested new Oracle Database deployment and will start migrating the data.
Best regards,
Felipe
