Failed to Paste
3457
10-18-2015 04:36 PM
DeanHowell1
I am trying to create a local file geodatabase from our MS SQL Server SDE database but get the following error.
The layer is a dimension layer created using ArcFM in ArcGIS 10.2.1
I have been able to copy all other layers except this one particular dimension layer.
Any clues would be very much appreciated.
Regards
Dean Howell
George_Thompson
Esri Notable Contributor
Hi Dean,
It looks like you do not have the correct Desktop extension enabled for that layer.
I have seen a similar error when copying over Network Datasets and not having the Network Analyst extension enabled in ArcMap/ArcCatalog.
I am going to take a guess and think you may need to check-out a Schematics license in Desktop.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Let me know how this goes?
-George
--- George T.
DeanHowell1
Thanks George, I think it was more a licence issue as I was trying to use a lower level than I needed. When I change to the higher licence level it seemed to work but I also found that not all features were copied but that seems to be a separate issue.
