Delete and Update operations in sequence to be followed
1589
08-04-2025 01:01 PM
Rohanrajan
I have been trying to select a number of features, delete some of them and update the rest. Like
edit = arcpy.da.Editor(workspace)
edit.startEditing(with_undo=True, multiuser_mode=False)
arcpy.AddMessage("Edit Session Started")
logging.info(f"Edit Session Started in : {workspace}")
try:
for id in Ids:
if id != Ids[0]
SearchCuror():
  UpdateCursor()
    deleteRow()
except arcpy.ExecuteError as e:
arcpy.AddMessage(f"Error: {e}")
for id in Ids:
SearchCuror():
  UpdateCursor()
    updateRow()
edit.stopOperation()
edit.stopEditing(save_changes=True)
But it encounters an error: Need an edit session
What am I doing wrong
Any advice is much appreciated
Tags (3)
VinceAngelo
Esri Esteemed Contributor
Please edit the question to place the code in a code block (click on "..." then "</>" in the second row of icons).
Reading Python code without indention is nearly impossible.
It's also nearly impossible to debug incomplete code (especially when there are TWO SearchCursor flavors [and arcpy.SearchCursor is deprecated, and should not be used in code written since 2013]).
But you should know that nesting cursors is an antipattern, and the likely cause of your error.
- V
DanPatterson
MVP Esteemed Contributor
To supplement Vince's suggestion, for the visual
Code formatting ... the Community Version - Esri Community
... sort of retired...
CodyPatterson
MVP Regular Contributor
Hey @Rohanrajan
This is a longshot, but it appears you're not performing an edit.startOperation() before starting the edit session.
Cody
