Could not rebuild indexes for dataset - Operation Failed [ORA-29858: Fehler bei Ausführung der Routine ODCIINDEXALTER
2191
05-01-2023 06:28 AM
Labels (2)
JamesMorrison1
Hello Everyone
Just trying to rebuild some indexes using the Rebuild Indexes Geoprocessing Tool in ArcGIS Pro in our new upgraded oracle and geodatabase Test environment passing in an sde connection file:
Geodatabase 11.1
ArcGIS Pro 3.1.0
Oracle 19.16.0.0
ST_GEOMETRY
Linux
Error message in ArcGIS Pro
Could not rebuild indexes for dataset DATA.DATA_LI.[
ORA-01652: Temp-Segment kann nicht um 128 in Tablespace TEMP2 erweitert werden
ORA-06512: in "SYS.DBMS_SQL", Zeile 1134
ORA-06512: in "SDE.ST_DOMAIN_METHODS", Zeile 1688
ORA-06512: in "SDE.ST_DOMAIN_METHODS", Zeile 2487]
ORA-06512: in "SDE.ST_DOMAIN_METHODS", Zeile 2487]]
From the error message I assume the TEMP2 tablespace is too small: ORA-01652: Temp-Segment kann nicht um 128 in Tablespace TEMP2 erweitert werden
It is currently set at: temp2.dbf is size 512m;
If it is too small - Does the rebuild operation in Oracle really use the temporary tablespace and why?
Thank you for the clarification
MarceloMarques
Yes the temporary index goes to the data tablespace but Oracle database still needs plenty of empty space in the Temp tablespace to perform other operations like sorting, etc.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
Temp 512mb is too small, set it to a large value 2gb or more, Oracle needs temp space to perform operations like sorting, etc., even during certain operations like rebuild index the Oracle database will need temp space.
JamesMorrison1
Thanks for your replay Marcelo - always appreciated.
I was a little confused. The feature class where I rebuild the index is a Schema called DATA1 and it has Tablespace called DATA (I'm making these names up for demonstration). And my old Oracle guide askTom (Tom Kyte) says....“Oracle will put the newly rebuilt index structure into a TEMP segment in the tablespace where the index is going to go.”
I assumed this would be DATA and not TEMP2? Or am I missing the point here?
MarceloMarques
JamesMorrison1
Thank you Marcelo always great feedback
