connect oracle 12c from arcgis for desktop and server 10.3.1
8246
11
06-22-2017 11:43 PM
ÖmerÜNSAL
New Contributor III
Problem: We can not connect to oracle 12c db from ArcGIS desktop and server 10.3.
db server info: Oracle 12c installed on Red Hat Enterprise Linux Server 7.3 OS
GIS Server:  arcgis for desktop and server 10.3.1 Installed on the same machine (windows server 2012 r2)
Oracle client info: oracle 12c 64x and 32x client installed on gis server. Oracle 12c 64x client before 32x oracle client on windows PATH Variable.
Other info
- Oracle DB and listener running, we connected oracle db from sql developer.
- We have moved oracle 11g db (with full backup) to new oracle 12c.
arcgis for desktop and server Connection errors attached.
"Database Connection
Failed to connect to the specified server. underlying DBMS error [unknown errorNo   extended error.]
shan_sarkar
Occasional Contributor III
Omer,
Have you tried to telnet?
I assume port 1521 is open for both the machines?
Have you tried to do an TNS entry for the Oracle client?
~Shan
~Shan
ÖmerÜNSAL
New Contributor III
Shantonu,
Yes, I did telnet connection to oracle db server.
 its ok.     tnsping and TNS entry for oracle client
JayantaPoddar
MVP Esteemed Contributor
What happens if you just type GIS as your Oracle instance in Database Connection dialog box?
Think Location
Asrujit_SenGupta
MVP Regular Contributor
  1. The successful connection using SQL Developer that you mentioned. Is the SQL Developer on the GIS Server?
  2. Were you able to connect using SQLPlus in Command Prompt on the GIS Server?
Considering you are using the default 1521 port, you don't need to mention that in the connection string. Just try IP/GIS.
ÖmerÜNSAL
New Contributor III
Our Oracle version 12.2
VinceAngelo
Esri Esteemed Contributor
The system requirements for 10.3 do not mention Oracle 12.2, just 12.1. In fact, ArcGIS 10.5.1 doesn't mention Oracle 12.2 either. I wouldn't expect the latest builds of Oracle to operate with an old version of ArcGIS.
- V
PrasadAmujuri
New Contributor II
Omer,
   I too got the similar issue. This is the problem with user credentials. You might have installed and configured the database with one user and now trying to access the database with another user or same or other domain. In this case you have to give permissions or share the oracle client folder with the new user.
-Prasad Amujuri
GangWang
New Contributor III
I had a similar issue - couldn't connect oracle 12.2 from 10.4.1 ArcGIS desktop. I have verified correct version of oracle client got installed and other requirements were met. I can TNSPING and connect successfully in SQL developer. Can anybody please confirm the issue is with unsupported version/release?
DivakarChennareddy
We have the same issue, did you find solution for your problem?
