Can I open a FGDB from Ms SQL Management Studio
1627
05-05-2022 10:59 AM
JoseSanchez
Hello everyone,
Can I open a FGDB from Ms SQL Management Studio?
Thanks
KimberlyGarbade
I don't think you can do it directly.  But of course I might be wrong, lets hope someone else knows a way.
Of course you can if you load the data from the file GDB into a SQL Server Enterprise GDB, but if you don't have the level of GIS software that allows you to do that you could try one more thing.
If you can create a personal geodatabase and copy the data into that, that format is an MS Access file type.   That you can either open directly in Access or bring it into SSMS.
George_Thompson
Esri Notable Contributor
I do not think that is possible to do. You would need an Esri client / FGDB clients to read it.
What are your wanting / trying to do with SSMS and the FGDB?
--- George T.
