Batch creating Database Sequences Using Python
1491
02-26-2024 11:54 AM
Labels (2)
gcromley
Greetings,  I'm new to the automation side of things in GIS.  I'm trying to use python to automate the creation of Database Sequences in an EGDB.  I get the following error:
ExecuteError: ERROR 001056: The input is not a valid Geodatabase.
However, the database connection file is valid.  My code is below.
import arcpy
import csv
arcpy.env.workspace = r"C:/Users/gcromley/Documents/ArcGIS/Projects/EnterpriseGIS/Development.sde"
csv_file = r"C:\Users\gcromley\Desktop\Book1.csv"
sequence_names = []
with open(csv_file, 'r') as file:
    reader = csv.reader(file)
    for row in reader:
        sequence_names.extend(row)
for seq_name in sequence_names:
    arcpy.management.CreateDatabaseSequence(r"C:/Users/gcromley/Documents/ArcGIS/Projects/EnterpriseGIS/Development.sde", seq_name,1,1)
elpsottile
Are you trying to create the next sequence value when you create a feature?
Have you tried this:
https://community.esri.com/t5/attribute-rules-videos/generating-unique-ids-with-attribute-rules/m-p/...
AlexanderDanielPratama
Based on Esri Documentation 001056: The input is not a valid Geodatabase.—ArcGIS Pro | Documentation, you need to upgrade the database. However, could you recheck the geodatabase connection properties that you have already checklist the checkbox of saving username-password.
Hope it helps you,
Cheers
