Discover how easy it is to create a database sequence for new features in your database using a calculation attribute rule and the NextSequenceValue Arcade function.
All users are required to work online. I am thinking it is a connection problem, but I have yet to pinpoint the cause.
there is chance they work offline and someone didnt update his local Database or conection problem and the data sent layer ?
I have created an attribute rule that creates a Unique ID based on the next number in the database sequence. When a public user submits an entry through Survey 123 it will create this Unique ID. I have noticed that sometimes two entries will have duplicate Unique IDs. I thought it could be a time delay issue but the creation date/time is a few hours apart. Any ideas?
Am I correct in thinking that AGOL does not support NextSequenceValue?
Hi how NextSequence work with multiple versions SDE?
Thanks for sharing this video Hussein,
we plan to use immediate attribute rule and NextSequence function to automatically set the bylaw enforcement Case # field to auto-populate with the next Case #. Example, 21-00001 would be the first record in year 2021, 21-00002 will be second and so on until the year changes to the next on December 31 then we need to re-set the counter to zero and update the year. Example 22-00001 for first record in 2022. Do you have any suggestions how to implement that?
Yes. Thank you so much!
Hey Jeff can you view this ? https://www.youtube.com/watch?v=QPV_ydeoVY0
Am I the only one that the video doesn't show up for?
