arcpy.da.ListSequences()
1062
04-06-2020 08:50 AM
JoeBorgione
The online help specifies:
At ArcGIS Pro 2.4, this function is only supported for file geodatabases.‍‍
Is this still the case at 2.5?
You can add a sequence to an enterprise gdb.....
Kory Kramer
That should just about do it....
KoryKramer
Esri Community Moderator
Hi Joe,
I've confirmed that this is currently only supported for file geodatabases.  We agree that the documentation is misleading and will be updated.  The team has been working on a way for this to work with enterprise geodatabases but that is more complex than working with file geodatabases so is not yet complete.  We'll be sure to keep the documentation updated as further capabilities are added.
Hope this helps.
Cheers
KoryKramer
Hi Joe,
Hope this helps.
Cheers
JoeBorgione
Thank you Kory.  There are few of those little gotchas that I stumble upon from time to time.  If you don't mind, I'd like to post them here on the forum with your attention.  That way the user community gets informed as well.  If you prefer a different procedure, just let me know.  Thanks again.
