appending to feature class and related tables
2030
01-17-2024 11:11 AM
Labels (3)
clt_cabq
I have some legacy data in a flat file that I want to import to a geodatabase where I have a 1:m feature class with related tables. Some records in the flat file will be appended to the feature class while other fields form records in a related table. What is the best way to accomplish this since new records imported into the FC will populate with a new GUID that will need to find its way into the related table's "parent GUID" when related records are added?
MarceloMarques
add new fields to the featureclass to hold the original primary key and original foreign key records. e.g. orig_pk , orig_fk.
perform the data load, then you can use a SQL Update statement to update the geodatabase relationship foreign key that can be based on the ObjectID or the GUI column.
SQL access to enterprise geodatabase data—ArcMap | Documentation (arcgis.com)
if you do not know SQL then you can use a Python Arcpy script or Model Builder or any other method in ArcGIS Pro to match the records using the original primary key and original foreign key and then update the foreign key using the ObjectID or GUI.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
clt_cabq
Thanks @MarceloMarques I suspected something along these lines was the correct approach, wanted to make sure I wasn't missing something though.
