Table.Extent value is wrong when geometry type is polygon
5686
8
02-24-2013 10:45 PM
MaoEdgar
I can't get the right extent of a table after inserting row into it, attached is the sample, I'm using the 1.2.0.136 version, can anyone tell me where goes wrong?
Edgar
VinceAngelo
Esri Esteemed Contributor
The C++ sample code shows a step you did not perform -- invoking CalculateExtent()
before SetGeometry.  That seems to correlate to improper envelope maintenance.
- V
VinceAngelo
Please download and use the 1.3 API.
Please provide your code in a CODE block.
- V
MaoEdgar
Here is my code, still the same result with 1.3 API
            Geodatabase geodatabase = Geodatabase.Create("b.gdb");
            string template = File.ReadAllText("../../template.xml");
            string tableDef = template.Replace("%Name%", "myTable").Replace("%ShapeType%", "esriGeometryPolygon");
            Table table = geodatabase.CreateTable(tableDef);
            string fieldTemplate = File.ReadAllText("../../fieldTemplate.xml");
            table.AddField(fieldTemplate.Replace("%Name%", "polygonField"));
            MultiPartShapeBuffer polygonShapeBuffer = new MultiPartShapeBuffer();
            int polygonPartCount = 1;
            int polygonPointCount = 5;
            int[] parts = new int[polygonPartCount];
            parts[0] = 0;
            List<Point> points = new List<Point>();
            points.Add(new Point(0, 0));
            points.Add(new Point(10, 0));
            points.Add(new Point(10, 10));
            points.Add(new Point(0, 10));
            polygonShapeBuffer.Setup(ShapeType.Polygon, polygonPartCount, polygonPointCount);
            polygonShapeBuffer.Parts = parts;
            polygonShapeBuffer.Points = points.ToArray();
            Row row = table.CreateRowObject();
            row.SetGeometry(polygonShapeBuffer);
            //NaN
            Console.WriteLine(string.Format("xMax:{0} yMax:{1} xMin:{2} yMin:{3}", table.Extent.xMax, table.Extent.yMax, table.Extent.xMin, table.Extent.yMin));
            table.Insert(row);
            //0
            Console.Read();
VinceAngelo
And what does the original XML say the extent should be?
- V
MaoEdgar
As you can see, the extent before I insert the polygon is NaN, then I insert a polygon((0 0, 10 0, 10 10, 0 10, 0 0)), so the extent should be changed to xMax:10 xMin:0 yMax:10 yMin:0, but it doesn't, it's 0.  If I use the xml from the FGDB sample, the extent is right,so I think there might be something wrong with my template, could you please have a look at that? The template is in the zip file in my first post.
Edgar
VinceAngelo
I'm not the best person to review your XML, but you could help your cause if you post it
as a singleton file.
- V
MaoEdgar
Alright, I found another way to recreate the problem, attached is the xml file I tested, you can download it if you needed, the code is below,
            Geodatabase geodatabase = Geodatabase.Create("../../TableSchemaDemo.gdb");
            string featureClassDef = "";
            using (StreamReader sr = new StreamReader("../../Streets.xml"))
                while (sr.Peek() >= 0)
                    featureClassDef += sr.ReadLine() + "\n";
                sr.Close();
            Table streetsTable = geodatabase.CreateTable(featureClassDef, "");
            Row row = streetsTable.CreateRowObject();
            MultiPartShapeBuffer line = new MultiPartShapeBuffer();
            line.Setup(ShapeType.Polyline, 1, 3);
            line.Parts = new int[] { 0 };
            Point[] points = new Point[3];
            points[0] = new Point(0, 0);
            points[1] = new Point(10, 0);
            points[2] = new Point(10, 10);
            line.Points = points;
            row.SetGeometry(line);
            streetsTable.Insert(row);
            //this two ways cannot query anything.
            RowCollection rows = streetsTable.Search("*", "", streetsTable.Extent, RowInstance.Recycle);
            //RowCollection rows = streetsTable.Search("*", "", new Envelope(9, 5, 11, 7), RowInstance.Recycle);
            //this way it returns one record.
            //RowCollection rows = streetsTable.Search("*", "", new Envelope(-1, -1, 11, 11), RowInstance.Recycle);
            foreach (Row item in rows)
                Console.WriteLine("Has row");
The Streets.xml is from the sample "\FileGDB_API_VS2010_1_3\samples\TableSchema\Streets.xml" and I haven't change anything, as you can see in the code I added a line into the table, and I want to query it by the table.Extent but failed, and then I changed the Envelope to (9, 5, 11, 7) which intersects the line, failed again, then I changed the Envelope to (-1, -1, 11, 11) which contains the line, it succeeded, so is there any way to query a record which is intersecting the specified Envelope?
Edgar
VinceAngelo
- V
MaoEdgar
Thank you, it's working fine now.
