Using proxy objects to read/write xml FileGDB schema using ADO.NET now available
3404
08-18-2011 08:33 AM
dotnetproviderdotnetprovider
Below is a sample of how to use proxy objects such as Field object to read/write FileGDB xml schema
ADO.NET for FileGDB supports proxy objects for Field, SubType, Domain, Fields, Table, FeatureClass and other schema objects.
Example:
https://github.com/dotnetprovider/FileGDB-.NET-provider/wiki/TableSchema-Sample
Use the link below to download ADO.NET for FileGDB (32 bits, 64Bits, VS2008, VS2010):
PrzemyslawTyrtania
First link is missing Proxy object or info on how to generate them? Second link is broken.
