Redefining S_OK, S_FALSE, SUCCEEDED, and FAILED is not very friendly
3241
05-19-2011 07:19 AM
MartinDaly
Could more FileGDB API-specific names be used instead?
Martin
DavidSousa
Martin
I am not sure that I understand the concern.  Can you elaborate on why you think this is a problem, and what you would propose instead?
The way these things have been redefined appears to be totally harmless.  The definitions are 100% consistent and functionally equivalent with the normal definitions in Windows.  It was necessary to do this in order to remove Windows dependencies.
-David
MartinDaly
-David
If they are "100% consistent and functionally" equivalent then why bother #undef-ing them first? If they are not there and you want them then check for their existence and only #define them if necessary. That would be 100% friendlier. Any file that #include-s them has messed up Intellisense that refers to your fgdbError.
Finally, they are 100% unused in the SDK-supplied headers; they are only used in the samples. If SDK client code needs them, then SDK client code should be responsible for ensuring their existence.
Martin
VinceAngelo
Esri Esteemed Contributor
Have you tried using the Beta-3 release?  These macros are all defined appropriately in FileGDBCore.h
(which is included by FileGDBAPI.h).
- V
__11
The existing definition (in API 1.3) is a problem, when building with Visual Studio 2010, because if I include winerror.h after FileGDBAP.h I get a macro redefinition warning. In general, I should not have to worry about what order I include the headers. This is especially so when there are multiple headers. My code is not at simple as
#include <winerror.h>
#include "FileGDBAPI.h"
It's actually:
// in main.cpp ...
    #include "AddFile.h"
// in AddFile.h ...
    #include "RunParameters.h"
// in RunParameters.h ...
    #include "Geo.h"
// in Geo.h ...
    #include <atlcomcli.h> // this includes winerror.h, which causes the warning
The solution is to #include AddFile.h before FileGDBAPI.h in main.cpp, but I shouldn't have to search through that many layers of header files (each of which has only the #inclusions it needs) to find the problem.
Regardless of the complexity of my own code and file structure, I should not have to worry about the order of inclusion of your and Microsoft's header files.
