Support for 9.x FGDB
3496
01-18-2013 08:45 AM
BrianBehling
Is ESRI planning on adding support for FGDB's created in 9.x anytime soon?
VinceAngelo
Esri Esteemed Contributor
No.  The simplification of the geodatabase storage model at 10.0 made it
possible to offer the FGDB API.  Supporting the earlier model would be
much more difficult.
- V
MarkCederholm
I might add that "upgrading" a file geodatabase from 9 to 10 causes problems with the API.  The only free-and-clear migration path is to create a new 10.x file gdb and copy the datasets to it.
LanceShipman
What problems are you seeing when you use an upgraded 9.x file geodatabase?
