Widget layout/styling question - first widget!
5284
8
08-30-2024 02:47 PM
DHighness
Hi, I built my very first EXB 1.15 React/Typescript widget and it works! The only issue I have now is figuring out how to do CSS so that it fits within a grid layout and doesn't flow off the page and adds a scroll bar. I have made this work by hacking the CSS and giving the Div a height but I'd like to be able to add it to any layout box and have that work. It could be I just haven't found the right layout widget to place it into?
The widget is a Layer Control type of widget that takes all the layers, Feature, Image and Map Image, in a Web Map and put then into a radio button list so you can toggle the layers and only display one layer at a time. The problem I face is the layer list gets long and goes off the page outside of the layout. I'd rather have it stay within the window and add a scroll bar. I have made it behave correctly by giving a height to the Div but I'd rather have this work automatically when I add the widget to a layout box. Any ideas?
Thanks
2 Solutions
JeffreyThompson2
MVP Frequent Contributor
I usually deal with this problem by using in-line style in the highest level div in my widget.tsx. Using in-line style overrides the CSS priority of the standard widget classes applied by Experience Builder.
<div style={{ "height": "inherit", "overflow": "auto" }}>
GIS Developer
City of Arlington, Texas
Nicole_Ueberschär
Thank you for the widget! A preview/demo would be nice.
JeffreyThompson2
GIS Developer
DHighness
That works as long as it's okay if the entire widget scrolls. I was hoping to have the widget header remain visible at the top and the lower box with radio buttons scroll. When I try that I can't figure out how to account for the height of the header. It's fine though, I need to get better at CSS.
import { IMThemeVariables, css, SerializedStyles } from 'jimu-core'
export function getStyle (theme: IMThemeVariables): SerializedStyles {
  const bg = theme.surfaces[1].bg
  return css`
    .widget-body {
        align-items: center;
        justify-content: right;
        font-size: 14px;
        background-color: ${bg};
        height: inherit;
        overflow: auto;
        .header-container {
          padding-top: 10px;
          padding-bottom: 10px;
          padding-left: 0.25rem;
          padding-right: 0.25rem;
          display: flex;
          justify-content: space-between;
          .header-title {
            font-weight:bold;
          .header-legend {
            padding-left: 5px;
        .body-radio-group {
          padding-left: 10px;
          /*height: inherit;*/
          /*overflow: auto;*/
          /*height: calc(100vh - 131px);*/
          .radio-box {
            display: flex;
            .radio-label {
              padding-left: 10px;
JeffreyThompson2
To get your header to stay in place you can use the position: sticky property.
https://www.w3schools.com/css/css_positioning.asp
As Experience Builder supports Bootstrap, you should be able to access it by adding the class "position-sticky" to the div with your header.
 https://getbootstrap.com/docs/5.3/utilities/position/
GIS Developer
DHighness
I added "position:sticky" to the header along with a background and "top:0" and that keeps the header at the top of the scroll list. Thanks for the help.
DHighness
Here is the code for my widget if anyone would like to use it. I put the code in a folder named "radio-layers" in the "/your-extentions/widgets/" folder.
GitHub Repo
JaredPilbeam2
Hi Dave,
The widget name in manifest.json is not the same with the folder name
Github download: Experience-Builder-Radio-Layers-Widget-main
manifest.json: radio-layers
Thanks for posting. In the process of checking the widget out I was getting a message in the client folder prompt telling me the folder name didn't match the widget name. Your Github download has a different name than the widget name in the manifest.json. Once I changed the download folder name it was fine.
 C:\arcgis-experience-builder-1.15\client\your-extensions\widgets\radion-layers
DHighness
I modified the readme.md to hopefully make that a little more clear.
Create a folder /your-extensions/widgets/radio-layers in Experience Builder Developer Edition 1.15 and copy the contents of the repository into it.
Nicole_Ueberschär
