Selecting Features from DataSource
6562
10
02-09-2024 05:09 PM
PartyPelican
Hello!
I am trying to create a widget that can select multiple layers based on a click event and show them in a series of tabs with a feature widget inside, however, I am new to development in experience builder. Currently I establish a click event listener on the map view and when the view is clicked, I query each FeatureLayerDataSource that is saved in state. I want to be able to select those results on the map but when I use datasource.selectRecordsByIds() with the object ids of the results, I dont see any highlighting on the map, and it appears as though my component renders twice. Its not clear to me why but you can see in the console that the tabs for each datasource gets rendered twice upon the click. This only happens when I use that selectRecordsByIds() method. Does anyone have any advice on how I can fix this or what I can do to make this work properly?
I appreciate any feedback, thank you.
2 Solutions
PartyPelican
I was on the right track with the selectRecordsByIds() method, I just forgot to pass in the array of records to select from as the second parameter. Once I did that, the feature was highlighted in the map.
PartyPelican
If anyone is interested, I have attached the working widget. I am still developing it and will share it again once I have made more improvements. Feel free to refactor the code and suggest ways to make it better.
Currently, you can supply it layers to select from on a mouse click (the mouse click uses a 10 ft buffer). The selection is applied to the data source so the selection can be seen by other widgets like the table widget.
Update:
I did some refactoring and added the option to change the buffer radius and units.
FredericPoliart_EsriAU
 you share the src code in a .zip ?
JeffreyThompson2
MVP Frequent Contributor
I am working on the same widget concept right now. Most of the work is done and I should be ready to release on here in a few days. Here is a preview.
GIS Developer
City of Arlington, Texas
PartyPelican
Awesome! do you mind sharing a snippet of how you went about querying and selecting the records? Eventually, I'd like to incorporate querying the related tables of a layer as well.
JeffreyThompson2
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Popup.html#fetchFeatures
It's based around the popup.fetchFeatures() method. The earliest version of my widget was based on this sample, but I think they have re-written some of it since I copied it.
GIS Developer
PartyPelican
SerjStol
@PartyPelican Wow I was searching everywhere why selectRecordById() was not working for me. Thanks! After parsing objectid AND FeatureDataRecord the selection worked! But the function says incorrectly that FeatureDataRecord is an optional parameter!? Terrible...
PartyPelican
Update:
RachappaBellappa1
Hello I am in the same boat, although selected features show the number of records selected but features are not selected in the map. I see the url's are updated with features. If i refresh the url then it shows selected features. Please check the code snippet.
Any thoughts
PartyPelican
Can you share your code please?
