Trying to update vertices of a line
1476
10-19-2024 04:58 PM
clc
I am writing a custom widget to allow user to modify the z value of the vertices of a line, but I can't figure out how to apply the changes.
Right now my widget is connected to a map widget and a feature layer datasource. I listen to double click to retrieve a line feature in the map. I then loop over all the vertices in the line and display their z value in an input. I can update the paths of the line with the values entered, but I can't figure out how to save these changes in my feature layer datasource so that these changes are available to all the other widgets in my experience.
JeffreyThompson2
MVP Frequent Contributor
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-support-Query.html#returnZ
I think to get the z values you must explicitly add returnGeometry = true and returnZ = true to your query.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#applyEdi...
So you are using the applyEdits() function, it updates the FeatureLayer, but the other widgets do not acknowledge the change?
GIS Developer
clc
I am so lost!
I wanted to edit the records of my datasource directly. This does not seem to be possible... So I use createJSAPILayerByDataSource() to get a feature layer. I then query the feature layer with the objectid of the polyline I double-click on to get the feature. I then can use applyEdits(). This works fine for updating any attributes  but not for changing the z of its vertices for the simple reason that there is no z in the vertices of the feature returned by the query. I used the same code for looping through the path of the polyline. When the polyline is obtained from the datasource it shows x, y and z (as it should because it is z-aware), when the polyline is obtained from the feature layer it shows only x and y!
JeffreyThompson2
GIS Developer
clc
You are right, I did not know about returnZ, I thought return Geometry was enough.
Thanks a lot for your help and all your posts.
Catherine
