Layer Focus Button - Custom Experience Builder Widget
2812
7
03-05-2025 09:58 AM
RasterFan98
Here is a simple custom widget: in the settings panel you can choose a map and a layer, and then the UI of the widget is a single button that when clicked will turn that selected layer on and all other layers off. It is not extensively tested, so use at your own risk and please post if you make any improvements to it.
JeffreyThompson2
MVP Frequent Contributor
@RasterFan98 Congratulations! Your widget was used as an example in the Plenary session at DevSummit.
GIS Developer
City of Arlington, Texas
AlderMaps
I saw it in action and came here hunting for it and/or other similar custom or ootb tools. Very cool!
TD1
@RasterFan98 can it turn 2 layers on and 2 layers off at the same time. More of a toggle?
TheRrrr42
If you do some small edits to the bookmarks widget, like turning the map pan to false.  You can turn the widget into something that flips multiple layers on and off.
RebekahPolette
Hi, where is this option to turn the map pan to false?
TheRrrr42
Inside of the bookmark widget.tsx you can comment out these lines. Doing so will remove the goTo and result in the bookmark widget just turning layers on and off.
Best,
Ricardo
SunshineLuke90
If you're looking for a custom widget to toggle between groups of layers, my "A better layer switcher" (ABLS) widget might be what you're looking for. You can find it on my GitHub here, or on NPM here, which you can install into your Experience Builder installation using the CLI that I've built, documentation here.
