Importing modular css into custom widget
1712
04-25-2025 11:16 AM
DanielWebb
In the ongoing saga of learning React and TypeScript while simultaneously troubleshooting the different versions of developer edition, I have a question.
In Experience Builder Developer Edition 1.11 I was able to import modular css.
import styles from "./my-styles.module.css";
Pretty basic stuff, I thought.
But when I try in ExB edition 1.16, styles is undefined?
Am I missing something obvious? Does developer edition no longer import modular css?
Thanks!
KenBuja
MVP Esteemed Contributor
The current documentation shows a simpler import
import 'path/to/style.css';
DanielWebb
I was able to get that to work but that imports css for the whole site, and so good naming conventions are more necessary to make sure there's no conflict with other stylings. Modular css is nice because it's contained and I can still use things like element.classList.remove(), and things like that.
DanielWebb
Does Esri have an answer to this yet? I'm moving on to Developer Edition 1.17 and facing the same issue. If Esri has a different way of finding and changing class names in JavaScript (i.e. an alternative to things like element.classList.contains() and element.classList.remove()), can someone provide me with examples?
Thank you!
