Enhanced ExB Coordinate widget
15287
28
06-22-2023 05:25 PM
Labels (2)
FredericPoliart_EsriAU
I have create an Enhanced Coordinate Widget display, with quick-link to Google3D
  • Very simple (just drag&drop and link to the map)
  • Works with 2D maps and 3D scenes
  • Shows Zoom level,  Scale,
  • Optionally shows Tilt (3D) and rotation
  • Can customize background color
How to use
  1. download from https://poliart.com/experiencebuilder/widgets/get-map-coordinates-class.zip
  2. unzip in your ExB Developer Edition: C:\ArcGISExperienceBuilder\client\your-extensions\widgets
  3. Restart your client/servers using npm start
  4. Drop this new widget onto your ExB Map Widget
  5. Settings: select the web-map
  6. Settings: select Show Tilt/ Rotation if you need
  7. done.
Let me know if you encounter any issue
Brian_McLeer
MVP Regular Contributor
12/10/2025 (for 1.19 version only):
  • Theme Typography Update – All widget text now uses Experience Builder’s Theme Typography for consistent styling.
  • Accessibility Improvements – Added multiple WCAG-compliant updates across widgets for better usability and accessibility.
Brian_McLeer
Update on 03/26/26: Breaking changes going from DE 1.19 to 1.20. Fix has been applied, both 1.19 and 1.20 available for use.
ZhujingXia
The widget worked in WGS84 coordinate, but my State Plane coordinate system would not work, is there a way to covert the lat and long into state plane?
Thank you .
Brian_McLeer
I was wondering the same thing, @ZhujingXia did you ever find a solution?
Martin1
This seems to be a widget which could help me a lot.
Is there are a newer version available which works with EXB Dev 1.14.
I always get an error message when starting npm in the client directory  (without the widget in the respective folder it works fine) :
"Field 'browser' doesn't contain a valid alias configuration
C:\...\ArcGISExperienceBuilder 1.14\client\src doesn't exist"
I haven't tested against 1.14 version of ExB dev edition.
I invite you to check the Geovonic Connect widget .  It has StreetView and Google Map integration as well as many other 3rd party apps (ex : select on the map, click the Geovonic Connect launch button > it launches your Asset application and shows the selected records. )
https://www.geovonic.com/geovonic-connect/
https://www.esri.com/partners/boustead-geospatial-a2T5x000008Dt9sEAC/geovonic-connect-a2d5x000006jPl...
https://connect.geovonic.com/
LefterisKoumis
Does this widget complies with the Google terms or service for their products?  Google TOS prohibits the use of their products on non Google based apps.
Brian_McLeer
From my interpretation of the TOS you can you can provide hyperlinks to Google Maps from a popup, attribute table, etc. to Google Maps which this widget does by passing coordinates in the URL.
Awesome work!! I am happy to see the widget is useful and has been improved. @DavidDas__GISP
you would have to modify the URL to be like this :
https://gis.maricopa.gov/pictometry/default.aspx?&qlat=33.44810033559447&qlong=-112.09697146843601
I haven't checked bu I think someone (above) has already modified the code and made a new .zip file
