Customize an out-of-the-box TABLE widget in 1.17
973
08-26-2025 02:48 PM
WilsonLee
Hello all,
We’re trying to customize the out-of-the-box Table widget in Experience Builder 1.17. Our goal is to remove or hide unwanted export formats (GeoJSON, JSON, and Items) and keep only CSV. Because the data will be added dynamically by another custom widget, we can’t control the export formats in the Data pane. the idea is to copy the out-of-the-box Table widget from C:\EXPB_DEV\ArcGISExperienceBuilder\client\dist\widgets\common\table, modify the code, and place it under C:\EXPB_DEV\ArcGISExperienceBuilder\client\your-extensions\widgets, then deploy.
This is new to us, and I’ll be working with our software developer. Are we headed in the right direction? Any tips would be appreciated.
Thank you,
Wilson
JeffreyThompson2
MVP Frequent Contributor
https://community.esri.com/t5/experience-builder-tips-and-tricks/modifying-esri-widgets-and-making-t...
Here is a guide covering the steps of converting an OOTB Widget to a Custom Widget.
GIS Developer
City of Arlington, Texas
WilsonLee
Thanks so much!!!
