Current logged in user and permissions
3751
01-11-2023 10:48 AM
MatthewClockel
I am building a custom widget that recognizes the logged in user so this can be applied to the UI.  My goal is for the application to recognize the current logged in user and display information on the tables and pages that pertains to the particular user.  So far I was able to create a custom widget that displays the username of the logged in user.    Any one have any experience with this and can help develop this.  This would be very useful for Esri experience builder users.
So far this is the code for the custom widget that displays the current user.  This is the widget.tsx file.
/** @jsx jsx */
import lang from "esri/core/lang";
import Credential from "esri/identity/Credential";
import IdentityManager from "esri/identity/IdentityManager";
import { React, AllWidgetProps, jsx, portalUtils, SessionManager } from "jimu-core";
import { getAppStore } from 'jimu-core';
import { userInfo } from "os";
import { userSignIn } from "../../../../../jimu-core/lib/app-actions";
export default class Widget extends React.PureComponent<AllWidgetProps<any>, any> {
    render() {
        let state = getAppStore().getState().user.username;
        return <div>{state}</div>;
When this widget is dragged into the UI of the application, the user name is displayed.
Grant-S-Carroll
If you want all the details related to a user, and the user has logged in, then you can obtain these details by making a call to the portal/self end point. See the REST API details here:
portal/self
This will return a detailed object for the user, including the users privileges and the groups that they are a member of.
Sample code:
   getUserDetails = (resp) => {
let token = this.props.token;
        const userUrl = this.props.portalUrl + '/sharing/rest/community/self?token=' + token + '&f=json'
        fetch(userUrl, {
        }).then(
            response => response.json()
        ).then((data: any) => {
            this.parseGetUserDetails(data);
            // Catch any errors we hit and update the app
            .catch((error: any) => {
                console.error(error);
                return null;
Grant-S-Carroll
portal/self
Sample code:
        fetch(userUrl, {
        }).then(
                return null;
MatthewClockel
This is great.  Thank you so much for this information.  This is exactly what I was looking for.
Ranga_Tolapi
I believe, user details can be fetched from
this.props.user
