Advanced Draw Widget Improvements: Import, Export, Save Drawings, Tool Tips, Snapping, Measurements
29993
117
05-28-2025 07:15 AM
Brian_McLeer
MVP Regular Contributor
40 117 30K
Advanced Draw Widget Capabilities
https://github.com/brianmcleer/draw-advanced-widget
This widget release builds upon contributions by @JeffreyThompson2 , @RobertScheitlin__GISP , and @AdrienHoff11 , incorporating all functions from prior iterations while adding significant new capabilities across two main areas, the Draw tab and My Drawings tab.
This release builds upon these prior releases:
Additional Draw Widget Improvements (4/10/2025)
Re-designed Draw widget (11/21/2023)
Draw Widget EB 1.7.0 (1/28/2022)
Draw Tab Enhancements
Measurement System
A comprehensive measurement system providing professional-grade accuracy and real-time calculations:
  • Real-time calculations – Automatic area, perimeter, length, and coordinate calculations that update as graphics are modified.
  • Multiple unit support – Distance units (kilometers, miles, meters, nautical miles, feet, yards) and area units (square kilometers, square miles, acres, hectares, square meters, square feet, square yards).
  • Custom unit definitions – User-defined distance and area units with conversion factors.
  • Coordinate display – XY coordinates, Lat/Long coordinates, and spatial reference WKID information.
  • Advanced measurements – Circle radius calculation and individual line segment measurements for complex shapes.
  • Intelligent processing – Geodetic vs planar calculations based on spatial reference, with automatic label management.
  • Configurable controls – Individual toggles for length, area, perimeter, radius, and segment displays.
Tooltips
  • Real-time measurements – Live tooltips with length, area, perimeter, radius, and coordinate updates as drawing progresses.
  • Configurable units & precision – Custom unit support and decimal rounding controls.
  • Smart placement & display – Automatic positioning and styling for clear visibility.
  • Interactive integration – Adapts to active drawing tools and user interactions like resizing and editing.
  • Coordinate display – Optional X/Y, Lat/Long, and WKID information for points.
  • Segment labels – Supports segment-specific tooltips for polylines.
  • Error handling – Fallbacks for unsupported geometries and projection warnings.
  • Performance optimized – Efficient rendering with minimal impact on performance.
Snapping
Advanced snapping functionality for precise drawing alignment:
  • Multi-layer snapping – Detects all visible snappable layers with recursive layer hierarchy search.
  • Comprehensive layer support – Includes feature layers, graphics layers, CSV, GeoJSON, WFS, and sublayers.
  • Smart functionality – 15-pixel snap tolerance, self-snapping, and temporary disable via Ctrl/Cmd key.
  • Automatic optimization – Layer loading and efficient snapping management with user feedback.
Drawing Tool Improvements
  • Reorganized layout – Two-row button arrangement with logical grouping (Point/Line/Freehand Line/Text top row; Rectangle/Polygon/Freehand Polygon/Circle bottom row).
  • Enhanced feedback – Clear indicators for "Drawing Mode," "Edit Mode," and "No Drawings Yet."
  • Dual-tab interface – Seamless sync between "Draw" and "My Drawings" tabs.
Text Tool Enhancements
  • Expanded font library – 11 font families including Alegreya, Josefin Slab, Merriweather, Montserrat, Noto Sans/Serif, Open Sans, Playfair Display.
  • Advanced styling – Real-time preview, enhanced rotation, multi-line support.
  • Sophisticated effects – Text outline/halo with size and opacity controls, font family selector.
Layer Management
  • Dynamic controls – Toggle visibility of the drawing layer in the map layer list.
  • Customization – Custom layer naming with collapsible settings panel.
  • Configuration options – Toggle between show/hide modes for the graphics layer.
My Drawings Tab
Storage & Data Management
  • Local storage integration – Saves drawings in browser with user consent management.
  • Session continuity – Remembers drawings across sessions on the same device/browser.
  • Load options – Detects existing drawings with options to load or start fresh.
  • Import/Export – JSON file-based backup and restore.
Drawing Organization
  • Selection system – Individual and bulk selection with checkboxes.
  • Sorting options – Sort drawings manually, by name, type, or creation date.
  • Search and filter – Easy navigation through large drawing collections.
Editing Capabilities
  • Name editing – Inline renaming of drawings.
  • Symbol modification – Edit drawing symbols and styles.
  • Text styling – Full text formatting including alignment, color, font, and decorations.
  • Copy/duplicate – Clone drawings for reuse.
User Experience Features
  • Confirmation dialogs – For single and bulk deletions.
  • Visual feedback – Selection highlighting and map interaction.
  • Accessible design – Tooltips, keyboard navigation, screen reader compatibility.
  • Responsive layout – Mobile-friendly with touch support.
Advanced Operations
  • Undo/Redo system – Full action history management.
  • Bulk operations – Multi-select delete, export, and modification.
  • Error handling – Robust error feedback and handling.
  • Performance optimization – Efficient rendering and memory management.
Features Not Currently Supported By ESRI Draw/Measure Widgets
  • XY Point Locations
  • Make Your Own Units of Measure
  • Measure Line Segments and Radius
  • Snapping Is An Easy-to-find User Option
  • Users Can Control The Number Of Decimal Places in Measurement
  • Users May Add/Remove Measurements After Drawing
  • Measurement Text Style Is Controllable
  • Point Symbol Rotation
  • Accurate Text Previews
  • User Options For Choosing the Name of the Drawing Layer and If It Displays in Map Layer List
  • Save Drawings To Local Storage and Retrieve Them in a Future Session
  • List of Drawings For Easy Management
Changelog
This widget release builds upon contributions by  ,  , and  , incorporating all functions from prior iterations while adding significant new capabilities across two main areas, the Draw tab and My Drawings tab.
Measurement System
Tooltips
Snapping
Layer Management
My Drawings Tab
Advanced Operations
Changelog
8/03/26:
  • Draw Advanced Widget is now compatible with Experience Builder Developer Edition 1.21, including support for the new pnpm dependency install.
7/21/26:
  • Fixed BUG reported and fixed by @ncramer11 where "Keep All (Merge)" was clearing the map before the new drawings got saved, so it silently dropped them instead of merging. This patches handleMergeDrawings to save the new drawings into storage first, then merge."
  • Add live measurements to segement labels thanks to idea from @JacobHildebrand
  • Add function to preset circle size before creation.
7/14/26:
  • Fixed GeoJSON export writing fully transparent graphics as opaque — transparency (alpha 0) is now preserved. Thanks to @ncramer11  for the fix.
7/1/26:
  • Fixed triangle and curve tools not switching into Drawing Mode (Identify now disables correctly during those draws).
  • Matched the "Send All (#)" count formatting on the Labels and Identify buttons.
  • Cleaned up label capitalization across the UI.
  • Security: hardened the settings XML import (CodeQL fix).
6/25/26:
  • Added an outline-only buffer option. Buffers can show just the outline with no fill.
  • Buffer custom color now has separate fill and outline colors. Pick each one independently.
  • Buffer geometry is now included in every export format (GeoJSON, shapefile, KML, and EB Draw), not just the parent attributes.
  • Added developer-configurable buffer defaults in settings: distance, unit, opacity, and color.
  • Added configurable measurement label templates for polyline and polygon labels.
  • Added settings import and export as XML. Save a widget configuration to a file and load it into another application to copy settings between experiences.
  • Standardized the settings panel on Jimu UI and made accessibility improvements throughout.
6/24/26:
6/23/26:
  • Added true curves line draw option: Bezier curve, arc segment, and endpoint arc that were added in JavaScript API 5
  • Added triangles to draw options
  • Fixed bug to disable or enable arrows on already created lines
6/9/26: Cleaned up the packaging based on standardization ideas from @SunshineLuke90  blog post, so the required modules now install automatically with the standard client install. No more need to run separate npm install commands for the shapefile dependencies. Thanks to everyone who has downloaded, tested, and sent feedback.
Bug Fixes:
  • Fix bug where a polygon buffer would reload as a circle around the polygon center instead of following the polygon edges (happens on page refresh, or when drawing before loading previous drawings).
  • Fix bug where buffers on complex or self-overlapping shapes, including shapes with crossing segments, produced odd results, whether drawn or copied from a layer.
  • Fix bug where buffers would not merge when features were copied from a map layer and merged before buffering.
  • Fix bug where using a buffer as a selection returned the wrong areas, which also cleans up selections sent to Mailing Labels and Identify.
  • Fix bug where Identify was not disabled when the Copy To Draw option was turned off.
  • Fix bug where segment labels were lost after reloading drawings from a previous session.
  • Fix bug where segment labels went away when clicking a drawing on the map or in the My Drawings list.
  • Fix bug where measurement and segment labels grouped in the middle of a graphic after resizing or reloading. Labels now stay along their segments.
  • Fix bug where duplicate, overlapping labels showed up while dragging a drawing.
  • Fix bug where multi-line text did not survive a GeoJSON export and re-import.
  • Fix several memory leaks from event listeners that were not being cleaned up.
Note: drawings saved before these fixes may have old data and are best redrawn. New drawings will reload fine.
5/5/26:
Minor bug fix to version 4.0 that resolves issue with merging multiple buffered features.
5/1/26:
Version 4 released: Supports integration with Identify By Query widget by @JeffreyThompson2
Add enhancement from idea from @ncramer11 to support multiple lines numbers for text.
VersionHighest Supported DE VersionNotes
draw-advanced_V21.19Version 2, no custom npm modules required
draw-advanced_3.11.19Version 3, custom npm modules required, compatible with 1.19 and earlier
draw-advanced_3.21.20Version 3, custom npm modules required, compatible with 1.20
draw-advanced_4.01.20Version 3, custom npm modules required, compatible with 1.20. Supports integration with custom Identify widget
4/01/26: DE 1.20 version available
3.1 = DE 1.19
3.2 = DE 1.20
3.2 Enhancements
  • Import/Export JSON to be compatible with OOTB Draw Widget Import/Export function.
3.2 BUG Fixes
@ncramer11 reported 2 bugs and both have been resolved
  • When adding a text graphic, the preview is duplicated. It seems that the text is being displayed in both a horizontal and vertical orientation.
  • When editing text that has already been placed on the map, the 'label text' field defaults to a print file name.
3/26/26: DE 1.20 broke something in this widget, need to troubleshoot
2/26/26: No updates to widget, but recent February 26 update to AGOL OOTB EB Draw widget added import/export JSON files. These JSON files are compatible to be imported into this widget. This widget does not currently support an export from this widget into the OOTB EB Draw Widget.
2/24/2026: 3.1 Released:
(view in My Videos)
Enhancements
Lock Drawing / All to prevent editing when locked
Measurement On/Off for one or all in My Drawings
Copy one vs multiple features at once
  • Select multiple by selecting with clicks, or by drawing by rectangle or polygon
  • Option to merge all features into one before pasting it into My Drawings
Send drawing graphic to Mailing Labels as selection
More control in settings to enable/disable tools/functions of widget
Bugs
Fix bug where when drawings are in prior session and user makes new drawings before loading, add to existing will wipe out prior drawings.
Fix bug where local storage does not always remember manual sort order upon reload
2/12/2026: BUG Fix: @KamilNovák reported an "issue with importing SHP files that use regional coordinate systems, specifically EPSG:5514. After importing such SHP data, nothing is displayed on the map, and it is also not possible to change the symbology of the imported graphics." This has been resolved. Thank you for reporting and testing @KamilNovák.
2/05/2026: V3 Released
(view in My Videos)
(view in My Videos)
(view in My Videos)
Required Optional Dependencies for V3 for shapefile import
and export (install on client folder):
npm install --save @mapbox/shp-write
npm install shpjs jszip --save
npm install shapefile
Enhancements:
Settings:
Allow users to store drawings per applications or globally
My Drawings Tab:
UI overhaul/new features to My Drawings are main updates of V3:
  • WCAG/Tooltip Audit
  • Import/Export supports KML and zipped shapefile now, while still maintaining GeoJSON and legacy JSON format.
  • New sort option: Manually move drawings so that order in map reflects order in list. Useful for example if a solid fill polygon is drawn after a point, point can be dragged to be on top of polygon. (idea from @Marshal  on 6/20/25)
  • Filter list by name to only show items in list from user text input
  • Copy Features from map layers
  • Grid styling
  • Linear unit-based grid option
  • Drawing notes and labeling
  • “In View” option to display drawings in list only in visible map extent
  • Collapse/Expand function to collapse or expand drawing details
  • Zoom All to zoom to all drawings (credit to @GeoguichetGeoguichet credited in updated manifest
  • Hide All – turn off drawings (redundant from map layers, uses may not enable to show in layers list or may not have layer list open all the time)
  • Labels – Label drawing name, notes (see below on notes), or both.
  • Single Drawings:
    • Label by name, notes, or both
    • Notes – dialogue box appears to store notes on drawing. This is exported as a field, could be useful in shapefile for users to populate their own field.
    • Visible – individual control visibility for drawings
    • Zoom To – zoom to single drawing extent
    • Move Up / Move Down – Move drawings up or down in list and that is how they will draw on map
Draw Tab:
  • Under enable snapping, added enable grid (with contributions from @GeoguichetGeoguichet )
  • Under Enable Buffer, add Label Buffer with a basic label with a leader line
  • Copy/Paste from selected feature on map layer (idea from @HeatherWidlund on 1/21/26)
Bug Fixes:
@JoshuaHouse  sent a DM about vertices not being able to be edited in Draw tab. Updated so that double clicking a graphic with either draw tab or my drawings tab active allows to edit vertices of line or polygon.
@GeoguichetGeoguichet on blog post reported issue with objects renaming. This has been resolved so that if a point is created it will go Point 1, Point 2, Point 3, a polygon it will go Polygon 1, Polygon 2, Polygon 3, etc.
@GeoguichetGeoguichet on blog post reported issue with import of points with picture symbols did not retain picture symbols. This has been resolved (tested before/after using Outdoor Recreation symbology set)
@adamsimple on blog post reported issue that it looks like there is a compatibility issue with ExB 1.19. The widget is attempting to access a legacy theme property. This has been resolved.
@KevinHitchcock reported that when length labels turned off and segment labels are on, “Total:” shows with no units reported. This has been resolved.
10/27/2025:
Bug fix: When going from Draw to My Drawings with a tool selected, the tool will stay active so you can still draw graphics when on the My Drawings Tab. The ZIP has been updated to resolve this bug.
10/15/2025: Version 2 released
Buffer
  • Add buffers to drawings including points, lines, polygons, and circles.
  • Configure buffer distance, unit, and opacity interactively.
  • Buffers update automatically when the parent drawing is reshaped or moved.
  • Buffers can be removed individually or cleared all at once.
  • Buffers are included in import and export operations.
Line Arrows
  • Add arrowheads to line drawings to indicate direction.
  • Arrowheads can be toggled on or off while drawing or after creation.
  • Works with both straight and freehand line tools.
  • Arrow styling integrates with existing line symbol settings.
Import/Export (GeoJSON)
  • Drawings can be imported from or exported as valid GeoJSON files.
  • Import GeoJSON created from other GIS tools or previous sessions.
  • Export GeoJSON for use in other applications, including ArcGIS Online and ArcGIS Pro. Note: For KML/KMZ, a third party or additional ArcGIS Pro geoprocessing operation will be needed (https://mygeodata.cloud/converter/, https://mapshaper.org, or others may be a viable option).
  • Maintains geometry and attributes for consistent round-tripping.
  • When importing into ArcGIS Pro single drawings in a GeoJSON file, use the JSON to Features geoprocessing tool and ensure the valid geometry is selected in the Geometry Type drop-down (text not supported).
  • When importing into ArcGIS Pro with multiple drawings in a GeoJSON file, use the Batch Import Data geoprocessing tool. This supports importing multiple geometry types from a single GeoJSON file (text not supported).
  • Legacy JSON files from previous versions of the widget can still be imported for compatibility.
Measurement Label Editing
  • Measurement labels can be repositioned by dragging.
  • Text properties such as size, color, font, halo, bold, italic, and underline can be adjusted.
  • Updates are applied instantly to labels on the map.
  • Supports editing labels for points, lines, polygons, and circles.
  • Improves map readability and customization without redrawing geometries.
Measurement Label Improvements – Special thanks to @MattiasEkström  for assistance on this portion
  • Segment labels for lines and polygons can now be rotated to match the orientation of the underlying segment.
  • Users can toggle between oriented labels (aligned with the line or polygon segment) and straight horizontal labels.
  • Rotated labels dynamically follow the shape of the line as it is edited.
  • This improves readability on curved or angled segments and provides more control over how measurements are displayed.
Delete All (My Drawings)
  • A new Delete All button has been added to the My Drawings panel.
  • Allows users to quickly remove all drawings at once.
  • Includes a confirmation step to prevent accidental deletion.
UI Updates
Known Issues
  • Circles Aren't Real - Circles generated by this Widget are actually 60-sided polygons and there is no good way to tell how a drawing was created after the fact. As far as this Widget is concerned, any polygon with exactly 60-sides is a circle. If you create your own polygon with exactly 60-sides or distort a circle so that it is no longer circular, it will be treated as if it is a circle and calculate a radius.
  • Freehand Line Segments - Technically, freehand line segments work fine, but they generate too many labels to be useful. For reasons similar to the circle problem above, there wasn't a good way of disabling the line segment option for freehand drawings, but it's a bad idea to use them.
  • Make Your Own Units Will Clear Your Default Unit Selection - After creating or editing your units in the Builder, your selected default unit will be cleared. You may need to select a unit of measure other than your desired choice, save Experience Builder and then switch back to your desired choice and save again. This issue is semi-intentional for the following reasons:
    • I could not get Experience Builder to recognize changes to the unit list and unlock the save button.
    • The default unit is passed as the index of an array, so creating or deleting units could result in the incorrect unit being selected or an out-of-range error.
  • Text Color Problems -
    • When first selecting a Background Color, you must first change to one of the Standard Colors. After selecting a Standard Color, all of the options will work.JeffreyThompson2_1-1748439750037.pngJeffreyThompson2_1-1748439750037.png
117 Comments
JeffreyThompson2
MVP Frequent Contributor
Give this a thumbs-up if you download. @Brian_McLeer deserves MVP status!
polkor_mcavoye
@Brian_McLeer this is really exciting! I can't wait to test it out!
RodWoodford
Great work All. Can't wait to test tomorrow.
cheers
Rod
ElisabethFenn
Wow, this is fantastic!
Marshal
Amazing job!!  Really appreciate the effort and collaboration for everyone involved here!
I will be publishing this to my production apps in the coming week.
Thanks!!!
RodWoodford
Hi All,
Set the widget up and its really well done. The segments lengths, export/import functions are fantastic. Really appreciate the work gone into this widget. I hope the development continues as we will be going live with this widget as we can't see ESRI evolve there own draw widget to much. It really helps us start to transition out of WABD. Well done.
cheers
Rod
Brian_McLeer
Thank you for the feedback all. If you see any issues or enhancements that may be possible, please feel free to post them in this thread.
PierreloupDucroix
Hello,
great job ! The import/export functionality is very useful.
We once developed similar widget for WAB 😉https://github.com/magis-nc/esri-webappbuilder-widget-eDraw
I am wondering whether it could be possible to list custom styles that are shared with the Portal ?
Following this documentation, we can share a style and use it in the mapviewer for feature symbology, but it could be very useful to use these styles in the draw widget, too.
Brian_McLeer
Thank you @PierreloupDucroix, we can make a note to look into this, but my time to spend on this widget is limited now. Thank you for the eDraw widget, that was motivation to create this widget as users in my organization did not like that import/export/save function went away with default EB draw widget. Used that as motivation and a framework to work with @JeffreyThompson2 to build upon the custom draw widget.
Marshal
Been using the widget a decent bit now, and it is absolutely great!  Just have a couple issues to report.
Major
  • When renaming a text object in My Drawings; the text value is replaced by the new given name.
    • It is pretty useful to give text annotations meaning names for reference in My Drawings, but not possible currently
  • When import json with text objects using the "Add" method; the text value is replaced by the name
    • Using "Replace" method correctly preserves the text value
Minor
  • While using Edit mode, the symbol selector is not synced with the chosen graphic geometry type and users are unable to change the symbol style (if not geometry has been initialized yet), or potentially shown the wrong symbol type for the selected geometry (e.g. point instead of polygon)
    • It would be handy if selecting a graphic in the map using Edit mode set the geometry type for the symbol selector, so that it stays in sync.
    • Currently the symbol selector is synced with the last chose graphic type.  So if a user draws a point, then deactivates Draw mode and goes into Edit mode.  Selects a polygon in the map and opens the symbol selector, it will then show styles for point geometry instead of polygon.
    • Minor issue since restyling graphic in My Drawing works as expected, and is likely a better workflow
  • Default UI does not translate well to dark mode apps, but was easily resolved with some restyling for my app theme (yes, I know dark mode was a choice!!)
Enhancement
  • Would be useful to change the layer/draw order for graphics in My Drawings, but I realize that is likely no easy task and a low priority enhancement.
Thanks again for all the hard work on this widget!
Brian_McLeer
Thank you @Marshal for the feedback, I sent you a direct message to get more information.
OneSpatialDude
Does this work in Enterprise 11.5? I keep getting a failed to load error. I was able to load the SaveInstance widget without issue so trying to figure out what I'm doing incorrectly.
JeffreyThompson2
@OneSpatialDude I'm not sure. The widget was built for 1.17. The compatibility table has not been updated for Enterprise 11.5. @Jianxia, please keep this table up to date. It is very important.
You might be able to make it work by changing the version in the manifest.json to 1.16 and compiling in that version of Developer Edition. I don't think we used any very new features from the API.
Edit: The measurement functions use several API features that were introduced in the 4.32 version of the API. This widget will not work in any version before 1.17.
Brian_McLeer
Update on 7/23/25: Tested widget on EB DE 1.18 and works as normal, but if anyone encounters issues in 1.18, please post them here.
MattiasEkström
Thanks for this widget that solves a lot of missing functionality in the draw widget!
I still need to customize it a bit, mainly translating to Swedish, but also some minor UI adjustments and maybe adding some new functionality if I succeed.
However when adding this wdget code to my Visual Studio Code project I get 280 problems only in the widget.tsx file. The code seems to be working fine but I think it is ESLint that has a lot of complaints.
I set up my developement enviroment accorrding to the documentation here: https://developers.arcgis.com/experience-builder/guide/getting-started-widget/ inclunding ESLint.
Do you guys use ESLint? and if so, how do you handle all the problems and warnings?
Brian_McLeer
Hi @MattiasEkström, thank you for the feedback. In my setup of VS I am not using ESLint. I would be curious to see any modifications you make for new functionality when it is ready!
TobySemroc
Hi @Brian_McLeer we are stuck at Enterprise 11.3/EB Dev Edition 1.14 for now. Is there a way to get a previous build of this widget that is compatible with 11.3?
Brian_McLeer
Hello @TobySemroc. Unfortunately I do not have EB DE 1.14, I built this in 1.17 and now I am on 1.18. However, our organization is on Enterprise 11.2 (soon to be 11.5) and we have had no issues using the latest version of DE as they are released. On one support case I had with Esri, they said it is best practice to stay within the compatibility matrix between EB DE and Enterprise, but usually it does not cause issue. If you are able to go to 1.17 or 1.18, I would recommend that.
MattiasEkström
Hi @Brian_McLeer, At first I really liked the idea of the IDE telling me as I type if the code is correct or not. I missed that in WAB development coming from Flex and actions script years ago, but I'm starting to question ESLint because it's lying to me.
Apart from all the problems in this widget code that I can just ignore, my first addition is a new draw style to draw arrows. It's really just a copy of the polyline tool, but it adds an arrow marker at the end of the line. ESLint is telling me that there is no marker property on the SimpleLineSymbol, but the documentation says it's been there since ArcGIS Maps SDK for JavaScript 4.16 , pretty annoying...
Brian_McLeer
@MattiasEkström I had a user call and ask about the arrows as we had that in our WAB apps, and not currently present in our EB apps. That would be a nice feature to add.
McKinneyPatrick_PA
I tried to add this widget to my Portal using the advice found at https://doc.arcgis.com/en/experience-builder/11.4/configure-widgets/add-custom-widgets.htm.
It appears this method expects a "dist" directory.  Is there a way that the downloaded zip can be built and a "dist" folder can be created?
Or is this custom widget only intended to be used with Developer Edition of Experience Builder?
JeffreyThompson2
@McKinneyPatrick_PA As this Widget was developed with Developer Edition 1.17, the earliest compatible version of Enterprise is 11.5.
For general information, please see this comment as to why the dist folder is not included and what you can do about it.
cdevault_pickett
@Brian_McLeer I have this widget deployed on EB 1.18 and Enterprise 11.4 and we just noticed that the JSON downloads can't be opened by ArcGIS Pro's JSON to Feature tool, Global Mapper or Google Earth. All report something about invalid JSON. ArcGIS Pro returns Error 001558
Has anyone else experienced this? Thanks for this widget! It's solved some of my user's major complaints about Experience Builder.
It looks to be a units issue, the coordinates are exporting as meters instead of degrees.
    "aggregateGeometries": null,
    "geometry": {
      "spatialReference": {
        "latestWkid": 3857,
        "wkid": 102100
      "paths": [
            -907115.167536391,
            308295.316683118
            -906101.916831046,
            307208.7882656357
MattiasEkström
I've made some adjustments to the widget. I started by translating everything to Swedish, I thought about replacing hardcoded text and making the widget translatable by the book, but it was a bit much so I took the quick route of just changing hardcoded text, which makes it pretty pointless to share my code here. But I'll try to describe the changes I made for a couple of specific featuresin case anyone finds it useful.
Buggfix:
When user have an active draw tool and clear all graphics, the draw tools gets inactive but the button is still selected so it looks like the drawtool should be selected.
In widget.tsx function ”drawClearBtnClick” either remove the line ” this.sketchViewModel.cancel();” this was my choice, or make sure to disable all buttons.
Added a draw arrow tool:
Make a copy of everything for drawing a polyline but change name to draw arrow or something, and add ’arrow’ to the list of possible drawtools.
In the function ”setDrawToolBtnState” ad a case to the switch(toolBtn) for arrow
case 'arrow':
		cState.currentSymbol = this.sketchViewModel.polylineSymbol;
		cState.currentSymbolType = JimuSymbolType.Polyline;
		this.sketchViewModel.polylineSymbol.marker = {
			color: cState.currentSymbol.color,
			placement: 'end',
			style: 'arrow'
		if(this.state.arrowBtnActive){
		}else{
		  this.sketchViewModel.create("polyline");
		  cState.arrowBtnActive = true;
		break;
where we’re adding an arrow marker at the end of the line with the same color as the line.
To make sure there are no arrows added to polylines drawn after the user has drawn an arrow we have to add  this.sketchViewModel.polylineSymbol.marker = null; to the polyline and freepolyline cases.
To make sure the arrow doesn’t disappear when editing symbology of an existing line I added this code:
if(this.state.currentTool === 'arrow'){
			color: evt.color,
			placement: 'end',
			style: 'arrow'
	  } else {
to the onPolylineSymbolChanged function.
Rotate segment measurements along lines:
I prefer segment measurements to be rotated along the segment lines, but obviously not upside down. I gave it a try and managed to accomplish something that works fairly well.
All modifications where made in measure.tsx
I added a new parameter called ‘angle’ to the function  “_addMeasurement”
const _addMeasurement = async (graphic: ExtendedGraphic, parentGraphic = null, angle:number = null) => {
And after this code (in that function)
 //for new graphics
} else {
    //copy textSymbol and insert measurement text
    const textSymbol = currentTextSymbol.clone()
    textSymbol.text = text
I added:
//If angle is passed, it is a segment mesurement and we will set rotation and override text vertical alignment and set offset based on angle.
			if(angle !== null){
				textSymbol.angle = angle
				textSymbol.verticalAlignment = 'bottom'
				//calculate offset depending on angle
				const distance = 4
				const angleRad = angle * Math.PI / 180;
  				const perpendicular = angleRad + Math.PI / 2;
				textSymbol.yoffset = Math.sin(perpendicular) * distance;
  				textSymbol.xoffset = Math.cos(perpendicular) * distance * -1.5;
I wrote a new function called _calculateAngle  to calculate the angle/rotation
const _calculateAngle = (x1:number, y1:number, x2:number, y2:number) => {
		const dx = x2 - x1;
		const dy = y2 - y1;
		const angleRad = Math.atan2(dy, dx);
		let angleDeg = angleRad * -180 / Math.PI;
		if (angleDeg > 90 || angleDeg < -90) {
  			angleDeg = (angleDeg + 180) % 360;
		return angleDeg
And makes call to that function and passes the angle three times in the liveMeasure function.
//make a templine for each segment and add a measurement for it
for (let j = 1; j < pointArray.length; j++) {
   const tempGraphic = makeTempLineGraphic(pointArray[j - 1], pointArray[j], geometry)
   const angle = _calculateAngle(pointArray[j - 1][0], pointArray[j - 1][1], pointArray[j][0], pointArray[j]    [1])
   _addMeasurement(tempGraphic, graphic, angle)
//line must have at least two points
if (geometry.paths[0].length > 1) {
   const lastPoint = geometry.paths[0][geometry.paths[0].length - 1]
   const nextToLastPoint = geometry.paths[0][geometry.paths[0].length - 2]
   const tempGraphic = makeTempLineGraphic(nextToLastPoint, lastPoint, geometry)
   const angle = _calculateAngle(nextToLastPoint[0], nextToLastPoint[1], lastPoint[0], lastPoint[1])
//calculate polygon segments
} else {
   const rings = geometry.rings
   for (let i = 0; i < rings.length; i++) {
      const ring = rings[i]
      for (let j = 1; j < ring.length; j++) {
          const tempGraphic = makeTempLineGraphic(ring[j - 1], ring[j], geometry)
          const angle = _calculateAngle(ring[j - 1][0], ring[j - 1][1], ring[j][0], ring[j][1])
shodge_fsu
It would be nice to be able to move your measurements slightly off of the lines segments so they are a bit easier to read.  Allowing the user to change their style would help too to make them easier to see and read.
Thank you for all the work here.  I am using this so I can add a small piece of text in your widget above the drawing mode icons to remind my users to double click to end lines and polygons.
Brian_McLeer
Sorry to respond to these all in one post, it looks like in a blog post you cannot reply to comments individually.
@cdevault_pickett I am not sure if we could get the JSON exports to be able to be viewed in ArcGIS Pro / Google Earth / etc. The intent of the JSON was to be read between various Experience Builder clients, but not beyond any EB apps with the Draw Advanced widget.
@MattiasEkström Thank you for the improvements, we may have a future release down the road with some bug fixes and enhancements, we can look to incorporate these into that release
@shodge_fsu it may be possible, @JeffreyThompson2 did all the heavy lifting for the measurement labels.
Nick_Rorke
Occasional Explorer
@Brian_McLeer We would love to install this in our Enterprise 11.3 site. Can you please provide installation instructions (apologies in advance if you've already done this and we've failed to find this info). Many thanks, Nick
JeffreyThompson2
@Nick_Rorke The earliest compatible version is Enterprise 11.5.
RodWoodford
Would it be possible to include a rotation on polylines and include directional arrows as part of the enhancement. Great tool. We are upgrading to 11.5 enterprise in the coming weeks and have version 1.18, is there likely to be any issues? I cant afford for this widget to break, our organization love it. Hopefully ESRI will catchup one day.
cheers Rod
JeffreyThompson2
@RodWoodford This Widget runs fine in 1.18 and should be compatible with registering in Enterprise 11.5. We, mostly @Brian_McLeer, are currently working on an update that includes arrowhead options for polylines.
RodWoodford
Excellent
RickEhlin__Jr
I just upgraded to 11.5 yesterday and tried to bring this draw advanced widget into my experience builder application....I'm able to get it to show up in my custom widget section of insert widgets, but it never loads.  I've tried a few things, but unfortunately can't seem to get it to work.  Any ideas or help would be appreciated.  Thanks.
JeffreyThompson2
@RickEhlin__Jr Did you compile in Developer Edition 1.18 before uploading? I am still on 11.3 so I can't upload test myself, but the error suggest the dist folder has not been created yet.
https://community.esri.com/t5/experience-builder-tips-and-tricks/registering-a-custom-widget-in-arcg...
RickEhlin__Jr
@JeffreyThompson2 I did not compile...I was under the impression this widget was already compiled and everything I needed was in the zip file.  I don't have developer edition of any kind....are there any custom widgets that are already compiled and ready to consume in 11.5?  Or do all of the custom widgets posted here need compiling?  Thanks for the response.
cdevault_pickett
Thanks @Brian_McLeer , I had a feeling that was the answer regarding the JSON exports.
Brian_McLeer
Version 2 released
Buffer
Line Arrows
UI Updates
Brian_McLeer
@cdevault_pickett V2 supports GeoJSON Exports
@RodWoodford V2 supports arrows on lines
@Marshal BUG you reported should be resolved in V2
@shodge_fsu in V2 Measurement labels have been improved with custom controls for moving and changing label
@MattiasEkström thank you for label improvements and BUG you reported should be resolved
Special thanks to @JeffreyThompson2 for collaborating on this version so we could get V2 out
shodge_fsu
@Brian_McLeer and @JeffreyThompson2 -- Thank you both for your work on this awesome widget.  The labels look great!  I know you are not looking for more things to do with this widget, but.....
It would be nice while you are drawing a multi-vertex line, each segment's length was displayed with each click, instead of only when you finish the drawiing.  That way if the user has some kind of directions that say, for example, go east for 125 feet, then north for 40 feet, then 600 feet north, they could easily track their progress.  I see how I can do this by turning on snapping and doing 3 individual line segments so this should be a LOW prriority.
Again - thanks for making this widget availible for everyone.
JeffreyThompson2
@shodge_fsu Even easier, you can turn on Tooltips. The Distance value is the segment length and you can also use the Tab key to manually enter a Distance or Deflection.
shodge_fsu
@JeffreyThompson2
Brilliant!  Just s short explanation in my splash page and I got it covered.
Thanks for the tip
RodWoodford
Hi @Brian_McLeer and @JeffreyThompson2  thank you gents for all the hard work on this widget. Will be downloading V2 asap.
cheers Rod
Brian_McLeer
The ZIP has been updated to resolve a BUG:
10/27/2025:
The patch was to private handleTabChange in widget.tsx. If you just want to patch your existing widget and not have to download the entire zip, replace the private handleTabChange with the below code snippet.
private handleTabChange = (nextTab: 'draw' | 'mydrawings') => {
  if (nextTab === 'mydrawings') {
    const drawings = this.snapshotDrawingsFromLayer();
    this.myDrawingsRef?.current?.ingestDrawings?.(drawings);
    // Stop any active drawing so clicks on My Drawings won't complete a shape
    this.setDrawToolBtnState('');
    try { this.sketchViewModel?.cancel(); } catch {}
    // Turn off edit mode only (keep existing measurement labels visible)
    this.measureRef?.current?.disableMeasurementEditing?.();
    this.setState({ graphics: drawings, activeTab: 'mydrawings' });
    return;
  // Back to Draw: FIRST disable measurements synchronously
  if (this.measureRef?.current) {
    // Disable measurements IMMEDIATELY before any state changes
    this.measureRef.current.setMeasurementEnabled?.(false);
  // THEN clear drawing tool and update state
  this.setState({
    activeTab: nextTab,
    measurementCheckboxOn: false,
    // Clear all drawing tool states
    pointBtnActive: false,
    lineBtnActive: false,
    flineBtnActive: false,
    rectBtnActive: false,
    polygonBtnActive: false,
    fpolygonBtnActive: false,
    circleBtnActive: false,
    textBtnActive: false,
    currentTool: ''
Thanks very much for sharing this.
A main concern for us is translation management that is unfortunately not present (all texts "hard coded").
It's the "badest part".
But otherwise very nice.
We added a ZoolAll function/button in "my drawings":
handleZoomAll = async () => {
  const { drawings } = this.state;
  const { jimuMapView } = this.props;
  if (!drawings || drawings.length === 0 || !jimuMapView?.view) return;
  const geometries = drawings
.map(g => g.geometry)
.filter(geom => !!geom);
  if (geometries.length === 0) return;
  let fullExtent = null;
  geometries.forEach(geom => {
const extent = geom.extent ?? geom;
if (!extent) return;
if (!fullExtent) {
  fullExtent = extent.clone ? extent.clone() : extent;
} else {
  fullExtent = fullExtent.union
? fullExtent.union(extent)
: fullExtent;
  if (!fullExtent) return;
  try {
await jimuMapView.view.goTo(fullExtent.expand(1.1), { animate: true, duration: 800 });
  } catch (err) {
Otherwise we added a draing share function that allows to save a drawing online and reopen it.
But I cannot share the code because there is some server side code for the upload.
Other interseting thing to add we thought, was the grif that is available in the standard widget:
toggleGrid = (enabled) => {
  const showGrid = enabled;
  this.setState({ gridEnabled: enabled }, () => {
if (showGrid && this.state.snappingEnabled) {
  this.drawGrid();
  this.state.currentJimuMapView?.view?.on("stationary", this.drawGrid);
} else {
  this.removeGrid();
drawGrid = () => {
  const view = this.state.currentJimuMapView?.view;
  if (!view || !this.state.gridEnabled) return;
  let gridLayer = view.map.findLayerById("draw-grid-layer");
  if (gridLayer) view.map.remove(gridLayer);
  gridLayer = new GraphicsLayer({ id: "draw-grid-layer" });
const featureSources = [];
if (gridLayer) {
  featureSources.push({ layer: gridLayer });
this.sketchViewModel.snappingOptions = {
enabled: true,
featureSources
  const origin = this.state.gridOrigin || { x: view.extent.xmin, y: view.extent.ymin };
  const angle = (this.state.gridAngle || 0) * Math.PI / 180;
  const spacing = this.state.gridSpacing || 100;
  const extent = view.extent;
  const diag = Math.sqrt(
Math.pow(extent.xmax - extent.xmin, 2) +
Math.pow(extent.ymax - extent.ymin, 2)
  const nX = Math.ceil(diag / spacing) + 2;
  const nY = Math.ceil(diag / spacing) + 2;
  const cosA = Math.cos(angle);
  const sinA = Math.sin(angle);
  for (let i = -nX; i <= nX; i++) {
const gx = origin.x + i * spacing;
const gy1 = origin.y - nY * spacing;
const gy2 = origin.y + nY * spacing;
const p1 = {
  x: (gx - origin.x) * cosA - (gy1 - origin.y) * sinA + origin.x,
  y: (gx - origin.x) * sinA + (gy1 - origin.y) * cosA + origin.y
const p2 = {
  x: (gx - origin.x) * cosA - (gy2 - origin.y) * sinA + origin.x,
  y: (gx - origin.x) * sinA + (gy2 - origin.y) * cosA + origin.y
const isMajorLine = (i % 10 === 0);
const color = isMajorLine ? [100, 100, 100, 0.7] : [200, 200, 200, 0.5];
gridLayer.add(new Graphic({
  geometry: {
type: "polyline",
paths: [[[p1.x, p1.y], [p2.x, p2.y]]],
spatialReference: view.spatialReference
  symbol: { type: "simple-line", color, width: 1 }
  for (let j = -nY; j <= nY; j++) {
const gy = origin.y + j * spacing;
const gx1 = origin.x - nX * spacing;
const gx2 = origin.x + nX * spacing;
const p1 = {
  x: (gx1 - origin.x) * cosA - (gy - origin.y) * sinA + origin.x,
  y: (gx1 - origin.x) * sinA + (gy - origin.y) * cosA + origin.y
const p2 = {
  x: (gx2 - origin.x) * cosA - (gy - origin.y) * sinA + origin.x,
  y: (gx2 - origin.x) * sinA + (gy - origin.y) * cosA + origin.y
const isMajorLine = (j % 10 === 0);
  geometry: {
type: "polyline",
  view.map.add(gridLayer);
removeGrid = () => {
  if (!view) return;
  const gridLayer = view.map.findLayerById("draw-grid-layer");
enabled: false
startGridPositioning = () => {
  if (this.gridClickHandle) {
    this.gridClickHandle.remove();
    this.gridClickHandle = null;
  this.gridPrevTool = this.state.currentTool;
  this.setDrawToolBtnState(''); // Désactive le mode dessin
  this.setState({ gridStep: 1 });
  if (!view) return;
  this.gridClickHandle = view.on("click", this.handleGridClick);
handleGridClick = (event) => {
  const { gridStep } = this.state;
  if (!view) return;
  if (gridStep === 1) {
this.setState({ gridOrigin: event.mapPoint, gridStep: 2 });
  } else if (gridStep === 2) {
// Second clic : définit l'espacement et l'orientation
const origin = this.state.gridOrigin;
const dx = event.mapPoint.x - origin.x;
const dy = event.mapPoint.y - origin.y;
const angle = Math.atan2(dy, dx) * 180 / Math.PI;
const spacing = Math.sqrt(dx * dx + dy * dy);
this.setState({ gridAngle: angle, gridSpacing: spacing, gridStep: 0 }, () => {
  this.drawGrid();
if (this.creationMode === 'continuous') {
switch (this.state.currentTool) {
case 'extent':
this.sketchViewModel.create('rectangle');
break;
case 'freepolyline':
this.sketchViewModel.create('polyline', { mode: 'freehand' });
break;
case 'polyline':
this.sketchViewModel.create('polyline');
break;
case 'point':
this.sketchViewModel.create('point');
break;
case 'polygon':
this.sketchViewModel.create('polygon');
break;
case 'freepolygon':
this.sketchViewModel.create('polygon', { mode: 'freehand' });
break;
case 'circle':
this.sketchViewModel.create('circle');
break;
case 'text':
// already applied text symbol above; start a new one
break;
default:
break;
  this.setDrawToolBtnState(this.gridPrevTool);
We also add issues with objects naming, depending on if we import, draw, delete, rename, etc.
=> svmGraCreate, first naming of the object:
g.attributes.name = `temp ${this.drawLayer.graphics.length + 1}`;
and then for the final name:
const regex = new RegExp(`^${this.state.currentTool}\\s+(\\d+)$`, "i");
const nums = this.drawLayer.graphics
  .filter(item =>
item.attributes &&
typeof item.attributes.name === "string" &&
item.attributes.name.toLowerCase().startsWith(this.state.currentTool)
  .map(item => {
const match = item.attributes.name.match(regex);
return match ? parseInt(match[1], 10) : null;
  .filter(num => num !== null);
const idx = (nums.length ? Math.max(...nums) : 0) + 1;
g.attributes.name = `${this.state.currentTool} ${idx}`;
best regards
Brian_McLeer
Thank you for the feedback @GeoguichetGeoguichet . Would you mind sending me a private message with your widget in a ZIP file? Currently we don't have plans for a V3, but we may be able to patch V2 with your bug findings.
OK, I'll try to do a proper file (we had to translate, what is to so easy with such code).
I'll come back when we are finished.
We found an issue: export and import of drawing does not work with picture markers.
best regards
Change in createSymbolFromJSONProperties:
const isPictureMarker = properties.symbolType === 'picture-marker' || properties.imageUrl || properties.iconUrl;
if (isPictureMarker) {
// Définir l'URL de l'image
const imageUrl = properties.imageUrl || properties.iconUrl;
// Taille (optionnelle)
const width = properties.imageWidth || 24;
const height = properties.imageHeight || 24;
// Rotation (optionnelle)
const angle = typeof properties.imageRotation === 'number' ? properties.imageRotation : 0;
return new PictureMarkerSymbol({
url: imageUrl,
width: width,
height: height,
angle: angle,
xoffset: properties.imageOffsetX || 0,
yoffset: properties.imageOffsetY || 0,
opacity: properties.image_opacity ?? 1,
color: properties.image_tint ? new Color(properties.image_tint) : undefined
} else {
return new SimpleMarkerSymbol({
style: finalMarkerStyle,
size: properties.marker_size || 12,
color: new Color(properties.marker_color || '#000000'),
outline: properties.stroke ? new SimpleLineSymbol({
color: new Color(properties.stroke || '#000000'),
width: properties.stroke_width || 1
}) : undefined
And in convertSymbolToStandardProperties:
(thanks AI)
case 'picture-marker':
const pic = symbol as __esri.PictureMarkerSymbol;
// Type du symbole (pour l’import à l’inverse)
properties.symbolType = 'picture-marker';
// URL de l’image
properties.imageUrl = pic.url;
// Largeur/hauteur (peuvent être number ou string dans certaines versions)
// -> on normalise vers number
const toNumber = (v: any, fallback: number) => {
  if (typeof v === 'number') return v;
  if (typeof v === 'string') {
const n = parseFloat(v);
return isNaN(n) ? fallback : n;
  return fallback;
properties.imageWidth = toNumber((pic as any).width, 24);
properties.imageHeight = toNumber((pic as any).height, 24);
// Rotation (en degrés)
properties.imageRotation = (pic as any).angle ?? 0;
// Offsets (décalage du symbole par rapport au point d’ancrage)
if (typeof (pic as any).xoffset === 'number') {
  properties.imageOffsetX = (pic as any).xoffset;
if (typeof (pic as any).yoffset === 'number') {
  properties.imageOffsetY = (pic as any).yoffset;
// Opacité globale du symbole (si disponible)
if (typeof (pic as any).opacity === 'number') {
  properties.image_opacity = (pic as any).opacity; // 0..1
// Tint (recolorisation) si utilisé
if ((pic as any).color) {
  const c = (pic as any).color;
  properties.image_tint = c.toHex?.() ?? '#000000';
  if (typeof c.a === 'number') {
properties.image_tint_opacity = c.a;
break;
Zoom all function that could be interesting:
  // Récupère toutes les géométries valides
  // Calcule l’emprise totale (union des extents)
//const extent = geom.extent ?? geom;
let extent: __esri.Extent | null = null;
  if (geom.extent) {
// Si la géométrie a déjà un extent (ex. polygone, ligne)
extent = geom.extent.clone();
  } else if (geom.type === "point") {
// Si c'est un point, créer un extent minimal autour du point
const point = geom as __esri.Point;
extent = new Extent({
  xmin: point.x,
  ymin: point.y,
  xmax: point.x,
  ymax: point.y,
  spatialReference: point.spatialReference
if (!fullExtent) {
} else {
: fullExtent;
  // Zoom sur l’emprise
  try {
  } catch (err) {
// Ignore si l’utilisateur interrompt le zoom
console.log(err);
About the Author
GIS Administrator/Developer at City of Grand Junction, CO.
