Improving a Density Analysis Using Attributes
4319
01-16-2019 12:27 PM
TimothyHales
Esri Notable Contributor
0 0 4,319
Density analysis calculates the number of events or objects across an area. The calculation results reveal where the highest concentration of points is within that area.
Did you know that you can also analyze points that represent a value greater than 1? Just because there may be a cluster of points does not necessarily mean that a certain area has the highest concentration.
All you need is an attribute with the quantities.
The following example shows you how density analysis is performed using attributes with the Point Density tool in ArcGIS Pro 2.2.
This map shows the address locations of reported crimes.
 Example of points
Each point may represent more than one report. The number of reports is stored in the Reports field in the attribute table.
Points table
  1. On the Analysis tab, click Tools.
  2. In the search box, type Point Density.
  3. On the Analysis tab, click Tools.
  4. Select your input points.
  5. For Population field, select the attribute with the quantity value.
    Your Point Density geoprocessing pane should look something like this:
    Point Density tool
  6. Set your output raster.
The output density raster shows the areas with the highest density based upon the number of reports at each address location. When you compare running the Point Density tool without a population field versus with a population field, you can see the difference in the results.
Point density without population
Point density with population
By adding in the population field, a high-density area becomes more apparent in the northern area of the map. Upon further investigation, that particular area contains a mall, shopping center, and movie theatre—which probably contributes to the higher number of crime reports.
Spatial analysis provides the tools you need to make informed decisions. Learning how to use the available tools will help you choose the specific analysis tool that will best meet your particular needs.
Are you new to spatial analysis? I suggest that you take a look at the Getting Started with Spatial Analysis web course. This course builds a foundation of knowledge on the six categories of spatial analysis and how they are used in the spatial analysis workflow. Additional information on density analysis can be found in the Calculating Density Using ArcGIS web course.
*Note: The data used in this example is fictitious and does not represent real crime data.
About the Author
Timothy Hales is a Senior Education Specialist for Esri Training Services developing instructor-led and web courses. Before developing training content for Training Services, he was the Enterprise Community Manager for Esri Community (GeoNet).
