In ArcGIS Pro, when you choose to share a layer to your ArcGIS Enterprise portal, you are presented with several options:
What happens when you choose each option? To answer that question, it is a good idea to understand the difference between data, layers, and services:
When you open a web map in your browser, the browser sends a request to the service. The service accesses the data and sends it to your browser in the appropriate format. The layer configuration determines how that data will be displayed in the map.
When sharing, the first choice you need to make is how the service should access the data. One option is to use a data store that you manage and give the service permission to access that data store. The most common reason to do this is because you want the service to use the authoritative data in your enterprise geodatabase. There are two sharing options in ArcGIS Pro that reference registered data.
This option creates a Map Image layer. The service will be accessible to client applications through a MapServer REST endpoint that looks like:
https://example.com/server/rest/services/ServiceName/MapServer
When you make a request to a MapServer URL, the service responds with an image drawn from the data in your user-managed data store to your client application. The way the image is drawn depends on the configuration of the Map Image layer.
When choosing to publish a Map Image layer by referencing registered data, you have the option to select Feature. If you do, you get a Feature layer item in addition to the Map Image layer. That Feature layer is made possible by a FeatureServer REST endpoint that looks like:
https://example.com/server/rest/services/ServiceName/FeatureServer
When you make a request to a FeatureServer URL, the service responds to your client application with the data from your user-managed data store, and your client draws an image of that data using the configuration of the Feature layer.
While the MapServer URL can handle both vector and raster data, the FeatureServer URL can only work with vector data.
This option creates a Tile layer (hosted). You also get a hosted VectorTileServer REST endpoint that looks like:
https://example.com/server/rest/services/Hosted/ServiceName/VectorTileServer
At the time of sharing, the service creates vector tiles of the data at many scales and caches those tiles. When you send a request to a VectorTileServer URL, it responds by returning the cached tiles. Because the service does not need to draw anything, that makes responses to these requests very fast. As the name implies, a VectorTileServer service is only able to handle vector data.
This option also creates a Map Image layer, Feature layer, MapServer URL, and FeatureServer URL, just as if you had created them directly by choosing the Map Image option. These other items allow you to update the cached vector tiles if the underlying data changes.
If you do not reference registered data, you must choose to copy the data into a location managed by ArcGIS. Some use cases require ArcGIS-managed data. In some cases, it can also be more convenient to release the responsibility of data management. When you copy all data, is important to note that if you delete the layer, the copy of the data is also deleted.
There are four sharing options that copy all data. Some of these options also create a Service Definition item in your portal content that can be safely deleted.
This option copies data into the ArcGIS-managed relational data store. You will get a Feature layer (hosted). You will also get a hosted FeatureServer REST endpoint that looks like:
https://example.com/server/rest/services/Hosted/ServiceName/FeatureServer
Just like a non-hosted FeatureServer, requests to this URL will return the data, and your client application will draw an image of the data.
This option copies the data to an ArcGIS-managed geodatabase on your ArcGIS Enterprise hosting server’s file system. It creates a Tile layer (hosted). You will also get a hosted MapServer REST endpoint that looks like:
https://example.com/server/rest/services/Hosted/ServiceName/MapServer
Like VectorTileServer, the service creates cached tiles of the data and responds to requests by sending back the cached tiles, so responses are fast. Unlike VectorTileServer, these tiles are rasterized, so this MapServer service can handle both vector and raster data.
This option copies the data to an ArcGIS-managed geodatabase on a federated ArcGIS Server site of your choice. Like sharing a Map Image by referencing registered data, it creates a non-hosted Map Image layer and a non-hosted MapServer REST endpoint.
By default, this choice has the Feature option selected. This copies the data to the ArcGIS-managed relational data store. It creates a Tile layer (hosted), a Feature layer (hosted), and hosted VectorTileServer and hosted FeatureServer REST endpoints. The vector tiles can be updated from changes made to the Feature layer.
You can also uncheck the Feature option. In that case, ArcGIS Pro creates a vector tile package. That package is uploaded to your portal’s Content directory. You will get a Tile layer (hosted) and a hosted VectorTileServer REST endpoint.
Some capabilities of ArcGIS rely on the existence of certain types of data, certain types of layers, or certain types of services. The table below summarizes what is created when you choose each sharing option in ArcGIS Pro.
Option | Data | REST endpoints created | Items created |
Map Image alone | remains in user-managed location |
Map Image with Feature selected | remains in user-managed location |
Vector Tile | remains in user-managed location |
Feature | Copied to relational data store |
Tile | Copied to hosting server directory |
Map Image | Copied to selected server directory |
Vector Tile with Feature selected | Copied to relational data store |
Vector Tile alone | Copied to portal Content directory |
For further ArcGIS Enterprise training, check out these Esri courses:
