This article provides you with a quick look at key information unique to this ArcGIS Enterprise exam, the level, and its exam versions. As always, our key exam preparation resources begin with Esri Academy where you'll find exam details and access the exam's corresponding learning plan, and Esri Community where you'll find the Exam Information Guide (EIG). Here is an article to help you select the exam that’s right for you: A Personalized Approach to Exam Selection.
We recommend that you subscribe opt in to receive certification updates in your inbox and subscribe to Esri Technical Certification in Esri Community to stay up to date on the latest program information. Click this link to Ask Questions.
The 2025 exam version is intended for candidates with at least 4+ years of applied experience using ArcGIS Enterprise. The exam tests the candidates’ skills related to configuration, designing, data distribution, data loading, maintenance, versioning, archiving, and tuning of enterprise geodatabases.
The 2201 exam version is a professional level exam. It is intended for candidates that have four years of applied experience and should be proficient in best practices and uses of ArcGIS related to the structure and function of enterprise geodatabases.
2025 Exam Version – In Development | 2201 Exam Version – Pending Retirement 31 December 2025 |
Design - 29% | Design - 29% |
Determine the appropriate geodatabase strategy that meets defined requirements | Determine the appropriate geodatabase strategy that meets defined requirements |
Determine the appropriate data association options within a normalized data model | Determine the appropriate data association options within a normalized data model |
Determine the appropriate method to store and serve data | Determine the appropriate method to store and serve data |
Determine the correct versioning and archiving workflow | Determine the correct versioning workflow |
Determine the correct data distribution solution | Determine the correct data distribution solution using scalability and data synchronization frequency |
Configuration 23% | Configuration 22% |
Determine how to create, enable, configure, and upgrade an enterprise geodatabase | Determine how to create, enable and configure an Enterprise geodatabase |
Apply the correct data security model implementation | Determine the correct data security model implementation |
Apply the correct distributed data configuration | Determine the correct distributed data configuration |
Manage mobile data workflows | Determine the correct process to manage mobile data workflows |
| Determine the correct data backup, recovery, and retention solutions |
Loading, Transferring, and Editing 17% | Loading, Transferring, and Editing 12% |
Understand the steps involved when using different data loading and updating options | Determine the steps involved when using different data loading options |
Understand the implications of using SQL with geodatabase editing | Determine the appropriate method when using SQL with a geodatabase |
Determine the correct workflow to migrate a geodatabase | Determine the correct workflow to migrate or upgrade a geodatabase |
Maintenance, Troubleshooting, and Performance 31% | Maintenance, Troubleshooting, and Performance 38% |
Troubleshoot issues with an enterprise geodatabase (i.e., performance, data sync, versioning, etc.)
| Troubleshoot performance issues with an Enterprise geodatabase |
Locate and interpret information in geodatabase system tables | Apply concepts to locate and interpret information in geodatabase system tables |
Determine the appropriate strategy to create and maintain indexes | Determine the appropriate strategy to create and maintain indexes |
Evaluate common connection or locking issues | Troubleshoot geodatabase versioning related issues |
Evaluate the application and workflow factors that affect database load and performance | Apply a strategy to administer geodatabase archiving |
| Determine how to resolve a common connection or locking issue |
| Troubleshoot distributed data synchronization issues |
| Troubleshoot advanced geodatabase functionality |
| Troubleshoot application and workflow factors that affect database load and performance |
Exams are updated every 18-24 months, and we welcome ArcGIS users and Subject Matter Experts to help shape the validity of our exam content. Your participation is critical to the success of our program, and your feedback is key to ensuring that the exam enhancements meet the needs of our GIS Industry.
