EGMP 2201 EIG
1220
02-14-2025 01:15 PM
JenniferParra
Enterprise Geodata Management Professional 2201 Exam Information Guide
Click here to return to the Esri Academy description page for this exam.
Exam Details
  • Exam Questions: 65
  • Exam Duration: 1 Hour, 45 Minutes
  • Exam Format: Multiple Choice
  • Exam Language: English
  • Certification Code: EGMP 2201
  • Exam State: Pending Retirement
    • Retirement Date: 31 December 2025
    • Read this article to learn more about exam retirement, and view the latest version of this exam, EGMP 2025, in Esri Community.
Exam Purpose
The Enterprise Geodata Management Professional exam tests the skills related to configuration, design, data loading, maintenance, versioning, archiving, tuning, and replication of enterprise geodatabases.
Target Candidate Audience
The Enterprise Geodata Management Professional exam is intended for candidates that typically have four years of applied experience and should be proficient in best practices and uses of ArcGIS related to the structure and function of enterprise geodatabases. Such as:
  • GIS Data Administrators
  • Database Administrators
  • GIS Administrators
  • GIS Analysts
  • GIS Data Managers
  • IT Administrators that work with GIS
Description of Qualified Candidate
The Enterprise Geodata Management Professional exam measures a candidate’s comprehension related to managing an enterprise geodatabase with advanced experience in a multi-user environment. Candidates should be able to understand the functionality and features of a geodatabase such as configuration and versioning.
Candidate Qualifications
A qualified candidate should be able to perform the following tasks:
  • Create and configure a geodatabase
  • Design a geodatabase (e.g., topology, attribute rules)
  • Understand workflows and the impact of each on a database
  • Manage data within a geodatabase or database
  • Perform geodatabase maintenance
  • Design versioning workflows (traditional and branch)
  • Troubleshoot geodatabase issues
  • Troubleshoot distributed data issues
  • Troubleshoot versioning issues
  • Troubleshoot performance issues
  • Implement distributed data workflows
  • Implement and support geodatabase replication
  • Implement feature services to edit data
  • Choose and utilize the appropriate Data Store configuration
  • Use views and SQL statements to access databases directly
  • Understand the different types of backups and the potential for data loss with each
  • Implement geodatabase archiving
  • Migrate or upgrade a geodatabase
  • Query repository tables
The following tasks are considered beyond the knowledge, skills, and abilities of the qualified candidate:
  • Implement RDBMS replication or high availability
  • Configure database storage
  • Install and upgrade RDBMS
  • Troubleshoot system or network performance
  • Perform RDBMS tracing
  • Develop custom applications to access the Enterprise geodatabase
  • Explain the system requirements of Relational Database Management Systems (RDBMS) for use with ArcGIS products
  • Use of specific design tools (e.g., Sparx Enterprise Architect Tool)
A qualified candidate should be familiar with the following:
  • ArcGIS Pro
  • ArcGIS Enterprise
Skills Measured
Candidates should use the exam content sections below as a checklist to identify gaps between their knowledge and the skills measured by the exam. The relative weight indicates the approximate size of each section. It is recommended that preparation be focused in areas where knowledge gaps are found.
Design 28%
  • Determine the appropriate geodatabase strategy that meets defined requirements
  • Determine the appropriate data association options within a normalized data model
  • Determine the appropriate method to store and serve data
  • Determine the correct versioning workflow
  • Determine the correct data distribution solution using scalability and data synchronization frequency
Configuration 22%
  • Determine how to create, enable and configure an Enterprise geodatabase
  • Determine the correct data security model implementation
  • Determine the correct distributed data configuration
  • Determine the correct process to manage mobile data workflows
  • Determine the correct data backup, recovery, and retention solutions
Loading, Transferring, and Editing 12%
  • Determine the steps involved when using different data loading options
  • Determine the appropriate method when using SQL with a geodatabase
  • Determine the correct workflow to migrate or upgrade a geodatabase
Maintenance, Troubleshooting, and Performances 38%
  • Troubleshoot performance issues with an Enterprise geodatabase
  • Apply concepts to locate and interpret information in geodatabase system tables
  • Determine the appropriate strategy to create and maintain indexes
  • Troubleshoot geodatabase versioning related issues
  • Apply a strategy to administer geodatabase archiving
  • Determine how to resolve a common connection or locking issue
  • Troubleshoot distributed data synchronization issues
  • Troubleshoot advanced geodatabase functionality
  • Troubleshoot application and workflow factors that affect database load and performance
Resources
To help prepare for the exam, we recommend candidates use the training resources provided below, along with reviewing the list of exam objectives, to identify and fill any knowledge gaps. Completing the recommended training courses does not guarantee a passing score on a certification exam.
The Esri-curated learning plan for this exam is updated regularly to reflect the latest Esri Academy resources and resource retirement schedules.
Esri Academy
Esri Community
Link to ArcGIS Documentation
Stay Connected
We hope you will subscribe to this article to keep up to date with the progress of this exam update and click this link to Ask Questions.
Contributors
About the Author
I am a Sr Global Training Specialist within Esri Training Services. I support exam development for the Technical Certification Program.
