EGMP 2025 EIG
4344
03-13-2025 10:45 AM
JenniferParra
ArcGIS Enterprise Geodata Management Professional 2025 Exam Information Guide
Click here to return to the Esri Academy description page for this exam.
Exam Details
  • Exam Questions: 75
  • Exam Duration: 1 Hour, 45 Minutes
  • Exam Format: Multiple Choice
  • Exam Language: English
  • Certification Code: EGMP_2025
  • Exam State: Available to Public
    • Published Date: 30 October 2025
    • Visit Esri Community to learn more about this exam
Exam Purpose
The ArcGIS Enterprise Geodata Management Professional 2025 exam tests the candidates’ skills related to configuration, designing, data distribution, data loading, maintenance, versioning, archiving, and tuning of enterprise geodatabases. It expects the candidates to have at least 4 years of applied experience with geodatabases.
Target Candidate Audience
The ArcGIS Enterprise Geodata Management Professional 2025 exam is intended for candidates that typically have 4 years of applied experience and should be proficient in best practices and uses of ArcGIS related to the structure and function of enterprise geodatabases. Roles may include:
  • GIS data administrators
  • Database administrators
  • GIS administrators
  • GIS analysts
  • GIS data managers
  • GIS enterprise architects
Description of Qualified Candidate
Qualified candidates should be proficient in best practices related to managing an enterprise geodatabase within a multi-user environment. This includes an understanding of the functionality and features of a geodatabase, such as configuration, data loading, maintenance, versioning (traditional and branch), archiving, tuning and data distribution. Candidates should have advanced experience with Esri's ArcGIS technology related to the structure and function of enterprise geodatabases.
Candidate Qualifications
A qualified candidate should be able to perform the following tasks:
  • Create and configure a geodatabase
  • Design a geodatabase (for example, topology, attribute rules)
  • Manage data within a geodatabase or database
  • Perform geodatabase maintenance
  • Design versioning workflows (traditional and branch)
  • Troubleshoot geodatabase issues (for example, versioning, performance)
  • Implement distributed data workflows
  • Implement and support geodatabase replication
  • Implement feature services to edit data
  • Choose and utilize the appropriate Data Store configuration
  • Use views and SQL statements to access databases directly
  • Understand the different types of backups and the potential for data loss with each
  • Implement geodatabase archiving
  • Migrate or upgrade a geodatabase
  • Query repository tables
The following tasks are considered beyond the knowledge, skills, and abilities of the qualified candidate:
  • Implement RDBMS replication or high availability
  • Configure database storage
  • Install and upgrade RDBMS
  • Troubleshoot system or network performance
  • Perform RDBMS tracing
  • Develop custom applications to access the Enterprise geodatabase
  • Explain the system requirements of Relational Database Management Systems (RDBMS) for use with ArcGIS products
  • Use of specific design tools (for example, Sparx Enterprise Architect Tool, SQL server management tool, and other similar tools)
A qualified candidate should be familiar with the following:
  • ArcGIS Enterprise 11.0- 11.4
  • ArcGIS Pro 3.0- 3.4
Skills Measured
Candidates should use the exam content sections below as a checklist to identify gaps between their knowledge and the skills measured by the exam. The relative weight indicates the approximate size of each section. It is recommended that preparation be focused in areas where knowledge gaps are found.
Design 29%
  • Determine the appropriate geodatabase strategy that meets defined requirements
  • Determine the appropriate data association options within a normalized data model
  • Determine the appropriate method to store and serve data
  • Determine the correct versioning and archiving workflow
  • Determine the correct data distribution solution
Configuration 23%
  • Determine how to create, enable, configure, and upgrade an enterprise geodatabase
  • Apply the correct data security model implementation
  • Apply the correct distributed data configuration
  • Manage mobile data workflows
Loading, Transferring, and Editing 17%
  • Understand the steps involved when using different data loading and updating options
  • Understand the implications of using SQL with geodatabase editing
  • Determine the correct workflow to migrate a geodatabase
Maintenance, Troubleshooting, and Performance 31%
  • Troubleshoot issues with an enterprise geodatabase (such as, performance, data sync, versioning, and other related issues)
  • Locate and interpret information in geodatabase system tables
  • Determine the appropriate strategy to create and maintain indexes
  • Evaluate common connection or locking issues
  • Evaluate the application and workflow factors that affect database load and performance
Resources
To help prepare for the exam, we recommend candidates use the training resources provided below, along with reviewing the list of exam objectives, to identify and fill any knowledge gaps. Completing the recommended training courses does not guarantee a passing score on a certification exam.
The Esri-curated learning plan for this exam is updated regularly to reflect the latest Esri Academy resources and resource retirement schedules.
Esri Academy
Esri Community
Link to ArcGIS Documentation
Stay Connected
We hope you will subscribe to this article to keep up to date with the progress of this exam update and click this link to Ask Questions.
Contributors
About the Author
I am a Sr Global Training Specialist within Esri Training Services. I support exam development for the Technical Certification Program.
