Top 20 Skills Exercise data extracts to empty folders
1744
09-19-2023 03:31 AM
Mike_Dumais
Exercise data download at links.esri.com/Pro20 for Top 20 Essential Skills for ArcGIS Pro (9781589487505) extracts to empty folders
Craig_Carpenter
Hi Mike,
Some folders are empty and this is expected. Certain chapters have you store data in those folders and others are used in different ways. You should find necessary data in folders when called for by the relevant chapters. Direct link here.
Craig
Craig_Carpenter
Hi Mike,
Craig
dlaytonfawcett
Hi Craig...do you know if completed practice files can be downloaded from anywhere? I could not succeed with the Join in chapter 4 of this book, and as a result, cannot proceed further in to the book.
Any help is appreciated.
Craig_Carpenter
Yep, I'll post a solution for you on your other thread that should get you squared away.
